New Member - York, SC
Check in here and say hi!
mbradford
#1 Post by mbradford » Mon Jan 05, 2015 7:27 pm
Picked up what we use to call in california a patio boat.
Found a 1988 20' Candy Kraft with a 50HP evinrude. Came with 10 life jackets, bimini top, cover, assorted other items and trailer.
I will take a picture tomorrow and post. Deck is solid all around. will have some questions on changing the prop, and maximum motor size a boat this size can take or need.
just my wife and I looking for an easy rider to float in the afternoon and evenings on Lake Wylie.
Mike
Re: New Member - York, SC
#2 Post by ROLAND » Tue Jan 06, 2015 3:17 am
Welcome to the group... Looking forward to your pics of your toon..
clrd
#3 Post by clrd » Tue Jan 06, 2015 8:10 am
Welcome. Would love to see the pics.
[color=#4040FF]2014 Bennington
21 SFXAPG
SPS and a 150 Yamaha[/color]
[img]http://i1274.photobucket.com/albums/y432/Chrisdarcy/0bbde953-3200-4434-b455-3a6fce451c63_zps16e878bf.jpg[/img]
redbeard
#4 Post by redbeard » Tue Jan 06, 2015 8:22 am
first welcome to the groupsecond the maximum size motor that you can run should be on your capacity tag
#5 Post by HandymanHerb » Tue Jan 06, 2015 9:12 am
Welcome, you can buy another pontoon with a bigger engine, cheaper than upgrading the engine
bassn386
#6 Post by bassn386 » Tue Jan 06, 2015 3:26 pm
Yep on engine upgrade. I found out it would be much cheaper to sell my existing toon and buy the same size with a bigger motor than it would be to up the HP on the one I have now. Not only that, but I would be putting a brand new motor on a 4 year old boat.
F225 Yamaha
smltooner
#7 Post by smltooner » Tue Jan 06, 2015 4:18 pm
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
mbradford
#8 Post by mbradford » Tue Jan 06, 2015 5:29 pm
thanks for the kind welcome.
not looking to swap the motor, was just wondering how big a motor it could handle.
The capacity tag is missing and I can't find much info on the manufacturer.
planning on using her as she sits.
ordered a new prop because the one on it was toast.
in the process of figuring where to mount the transponder for the depth finder i picked up. I know it goes on the accessory tab on the starboard pontoon.
thanks again and looking forward to learning from you all.
Mike
Gonefishing
#9 Post by Gonefishing » Tue Jan 06, 2015 6:23 pm
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
#10 Post by RcgTexas » Tue Jan 06, 2015 8:26 pm
Welcome!
Waterlogged
#11 Post by Waterlogged » Wed Jan 07, 2015 10:42 am
Welcome aboard. On a boat that old you likely have small diameter toons which might limit motor size. 50hp may be near max.
Glenn
2008 Mercury 115 4 stroke
Discovery
#12 Post by Discovery » Wed Jan 07, 2015 12:54 pm
Welcome aboard.
peterb803
#13 Post by peterb803 » Fri Feb 20, 2015 9:05 am
welcome from a fellow S Clinian.
couple of things.....
you might want to speak with the SCWMR Dept. and the N.C. law. about the missing tag.
The state line runs right down the middle of Wylie. If your on the N.C. side, you will have to be N.C. legal.
Wylie is a fun lake....good fishing....
good luck...
pb
grouser
#14 Post by grouser » Fri Feb 20, 2015 8:26 pm
Welcome from the State of Jefferson
