1st Pontoon
Check in here and say hi!
gobeernet
1st Pontoon
#1 Post by gobeernet » Mon Feb 02, 2015 7:47 pm
Had a couple ~20' ski boats in the past. Sold everything a few years ago. Got the itch to get back on the water so I picked up a '99 22' Bennington with 115 Mercury last weekend. Its a fishing setup although I don't fish. I liked the motor, length and empty space on the front and back.
I'm sure I'll just enjoy for now. Once I gain some confidence in the platform I'll start tinkering. Prop is a bent up so that is high on the list. Next is a moderate radio upgrade, current radio is staticy and down to one speaker. I'd also like to move the seating around a bit. In the end, I'd like a ladder in the rear and front instead (or in addition) to each side.
Now to browse the forum to fuel the upgrade fire since its too cold to use it.
It floats, I'm happy.
Re: 1st Pontoon
#2 Post by curtiscapk » Mon Feb 02, 2015 8:00 pm
Welcome! Look all over. Check out my rebuild in my sig!
Re: 1st Pontoon
#3 Post by RcgTexas » Mon Feb 02, 2015 8:45 pm
Welcome! Yep there is a boat load of info and help here!
smltooner
Re: 1st Pontoon
#4 Post by smltooner » Tue Feb 03, 2015 2:00 am
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
gobeernet
Re: 1st Pontoon
#5 Post by gobeernet » Tue Feb 03, 2015 8:23 pm
RcgTexas wrote:Welcome! Yep there is a boat load of info and help here!
Is there a write up of your tritoon conversion. I searched and didn't find one by you.
I'm jumping the gun, but its cold, so instead of using my toon, i'm dreaming about upgrades like a third toon. Seems to be a good bit of conflicting info about the conversions.
redbeard
Re: 1st Pontoon
#6 Post by redbeard » Thu Feb 05, 2015 8:29 am
welcome to the group
Chillaxin'
Re: 1st Pontoon
#7 Post by Chillaxin' » Thu Feb 05, 2015 3:57 pm
What, no pics? :lol3
[color=#000080][b]USAF (Retired)
2014 22' Sweetwater 2286 Cruise
Yamaha F-70 LA 4-Stroke[/color]
[color=#BF4000]I'm always at the Helm; she's always on the Bow Lounger![/b][/color]
Waterlogged
Re: 1st Pontoon
#8 Post by Waterlogged » Fri Feb 06, 2015 11:02 am
Welcome aboard gobeernet. Good luck with any upgrades you do.
Glenn
2008 Mercury 115 4 stroke
gobeernet
Re: 1st Pontoon
#9 Post by gobeernet » Sat Feb 07, 2015 9:32 pm
Chillaxin' wrote:What, no pics? :lol3
Viola, pick of todays maiden voyage.
Gear shift is mighty stiff. Is there anyway to lube these cables?
The motor ran out fairly well. If idling for a while, it will load up and die. PITA to start back. Now that I"ve had it out, I'll dig into it a bit. Check compression, new plugs. I'll look for a fuel filter.
Prop is dinged up with a good sized bend and small tear. Top speed is 22mpg gps. Once I get more confidence in the platform, I'll get a new one.
Got some water in the RH tube. I guess I can pull a plug and suck it out. Then pressurize with soapy water to find the leak. What pressure do I use?
Maiden Voyage
gobeernet
Re: 1st Pontoon
#10 Post by gobeernet » Sat Feb 07, 2015 9:41 pm
wow, sorry for the massive image. I'll see if I can tame that down when I get back to a PC.
The toons have a significant water line. I used aliminex on the back half of the right side toon. Its leaving the aluminum a chalky white that doesn't look good. Any suggestions? I've read alot of polishing threads and that sounds like more than I'm up to. The toons have dings, etc. I'd like to get a "clean" and uniform finish. I'm not concerned with a polished finish. A dull aluminum finish would be fine with me. Can I sand the toons? What type and size of sander and what grit should I use?
grouser
Re: 1st Pontoon
#11 Post by grouser » Sat Feb 07, 2015 10:29 pm
Welcome to the madness,,,
