Hello New to boating & forum. Bilge pump on tri-toon?
Check in here and say hi!
Hi-C
#1 Post by Hi-C » Wed May 13, 2015 9:53 pm
New member. New to boating. Have a Sylvan 27' tri-toon with 150 Mercury engine. Joined for learning about boating, especially a pontoon boat. Boating on the Barnegat Bay in NJ.
Question: This tri-toon boat has an electric bilge switch. Since I have no manual, why a bilge pump for a trii-toon :?: Would anyone know when and how to use and maintain it :?: Thanks.
Re: Hello New to boating & forum. Bilge pump on tri-toon?
#2 Post by Bamaman » Thu May 14, 2015 4:40 am
Does the switch do anything, and can you hear a pump running?
If you have a middle toon ski locker, it might be for a pump down there.
Many dash panels on boats have switches that are not applicable--used on different types of boats.
ToonGuy
#3 Post by ToonGuy » Thu May 14, 2015 5:26 am
Welcome. Most likely you have a pump below your ski locker in your center tube.
:thumbsup
Mucho Gusto
#4 Post by Mucho Gusto » Thu May 14, 2015 10:12 am
Absolutely right. On my Tritoon, the bilge bump is in the rear of the ski locker. Makes it nice and easy to get rid of the water collected from life jackets, kneeboarding etc..
Kyds
#5 Post by Kyds » Thu May 14, 2015 12:31 pm
This is question I've had as well. I know I have a pump in the ski locker but I was told by the dealer that it is automatic and not run by any of the switches? Can anyone elaborate on that? I've had to have it replaced once.
2010 22ft Aqua Patio Tri-toon w/ 150 Yamaha
grouser
#6 Post by grouser » Fri May 15, 2015 4:25 pm
The pumps can be set up to be automatic,,, and usually if you want to turn it on at the helm there is a manual override,,,cuz your the Captain and if you wanna pump it out then you can !!,,, Otherwise it waits untill it gets to a certain depth then pumps
Welcome from the State of Jefferson
smltooner
#7 Post by smltooner » Fri May 15, 2015 6:12 pm
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
zoom650
#8 Post by zoom650 » Sun May 17, 2015 7:14 am
First, welcome!
My boat's ski locker has a bilge, located in a well in the aft end of the locker. It is automatic, as long as the battery is switched on. There's also a dash switch for manual operation if the water level is not high enough to trip the float switch.
I've never had to maintain or replace a bilge. Of all the pumps on various boats I've owned, the bilge has been the most reliable.
Mucho Gusto
#9 Post by Mucho Gusto » Sun May 17, 2015 9:05 am
zoom650 wrote:First, welcome!
You just set yourself up for failure there, zoom! :biggrin2 :biggrin2 :biggrin2
Hi-C
#10 Post by Hi-C » Sun May 17, 2015 7:04 pm
If I don't have a ski locker, why is there a bilge pump in the center pontoon of a tri-toon?
zoom650
#11 Post by zoom650 » Mon May 18, 2015 6:40 pm
Mucho Gusto wrote:
zoom650 wrote:I've never had to maintain or replace a bilge. Of all the pumps on various boats I've owned, the bilge has been the most reliable.
Oh, great. I'll have to hope those 4 fresh water wash down pumps and two maserators counted for something!
