washdown system?
Check in here and say hi!
bsmith77327
washdown system?
#1 Post by bsmith77327 » Thu Sep 03, 2015 12:49 pm
I have ordered a 94639 pump from harbor freight, what hose is used on most units? I have
seen 3/8 coiled hose for marine use. I tried a regular garden hose and it would not pick up.
Any advice?.
2014 Sun tracker 20 dlx fishin garge mercury 60 big foot
HarryO
Re: washdown system?
#2 Post by HarryO » Thu Sep 03, 2015 2:11 pm
I have the same pump and you have to prime it with a couple of ounces of water before it will work.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
bsmith77327
#3 Post by bsmith77327 » Thu Sep 03, 2015 2:39 pm
What size hose do you have on it
teecro
#4 Post by teecro » Thu Sep 03, 2015 3:29 pm
On the suction side be sure to use a rigid hose as soft garden hose will collapse in use; I'd use 1/2" 5/8" or even 3/4" on the discharge side a 3/8" coiled hose would work fine. You need to be sure you hook the suction and discharge up to the correct side of the pump and don't be surprised if you need to wet the impeller first to get suction going. I'd install a check or foot valve on the suction to keep the pump primed at all times.
