Chemical Toilet
Check in here and say hi!
doodlemom
Chemical Toilet
#1 Post by doodlemom » Fri Oct 15, 2010 3:07 pm
Any advice on using the bathroom on a pontoon? I have a boat with the pull down changing room but wow, it pulls down from the bimini top right smack dab in the middle of the boat. Who would want to use a chemical toilet in there?
Any suggestions? :scared
Re: Chemical Toilet
#2 Post by lakerunner » Fri Oct 15, 2010 6:56 pm
Whats the diff between the middle, front, or rear of boat? When you gotta go ya gotta go
Ron Burgundy
Re: Chemical Toilet
#3 Post by Ron Burgundy » Fri Oct 15, 2010 6:58 pm
My advice...tell your passengers to stand up wind... :thumbsup
Bamby
Re: Chemical Toilet
#4 Post by Bamby » Sat Oct 16, 2010 5:28 am
Get yourself a Port-a-potty
Port-a-potties require no plumbing; they may or may not have a reservoir for flush water. Bowl contents drain by gravity into a removable tank which is carried off the boat and dumped, although some larger models can be fitted for pump-out. Typically they hold between two and five gallons. An upgraded version is the SeaLand "Marine Traveler," which is a toilet bowl atop its own 9-gallon tank which is fitted for pump-out, and uses pressurized water from the onboard system, but very little of it. Port-a-potties are automatically CG Certified Type III MSDs.
Also if you use the right deodorant (and the cheap stuff at Wally World ain't it either don't ask how we know) you'll have no real odors except your own when in actual use. As far as the sound of your tinkling reverberating around the boat, your on your own on that. :lol3
mike
Site Owner
Re: Chemical Toilet
#5 Post by mike » Sat Oct 16, 2010 8:21 am
I bought a thetford for ours, its nice and portable so I can stick in the back of our minivan on long road trips! :nana
Re: Chemical Toilet
#6 Post by lakerunner » Sun Oct 17, 2010 8:23 am
For young flexible ladies I have a gal coffee can, for old stiff ladies a 5 gal bucket
Lulu
Re: Chemical Toilet
#7 Post by Lulu » Sun Oct 24, 2010 6:52 am
Mike - How expensive was your portable one? We need something like this on our boat!
Re: Chemical Toilet
#8 Post by dockholiday » Sun Oct 24, 2010 8:41 am
Lulu get the tallest model you can. Some are not very high. Should be able to pick up one for 100-125.
Lulu
Re: Chemical Toilet
#9 Post by Lulu » Sun Oct 24, 2010 8:56 am
Thanks. Will keep that in mind!!!
Ray Jr.
Re: Chemical Toilet
#10 Post by Ray Jr. » Sun Oct 24, 2010 9:31 am
We got a thetford for ours and it works great, it is the taller model,(larger holding tank) and we got it at walmart for $80.
2010 150 HP Mercury Optimax
rsmith
Re: Chemical Toilet
#11 Post by rsmith » Sun Oct 24, 2010 4:19 pm
We've got a pumpout head on our toon. Might just be the best option we put on our boat. Wife said hell no to a standard porti-potti and I'm glad she stood firm on that one. First option is always the bathroom at the marina or the well established prop check routines, but when the water is in the 40s or 50s or we trolling while fishing using the on-board head is the only option.
200hp Mercury Verado
mike
Site Owner
Re: Chemical Toilet
#12 Post by mike » Sun Oct 24, 2010 6:12 pm
Lulu wrote:Mike - How expensive was your portable one? We need something like this on our boat!
Just over $100 on amazon, this is actually a newer model to the one I bought but its about the same size...
http://www.amazon.com/Thetford-25112-Po ... 080&sr=8-1
Re: Chemical Toilet
#13 Post by dockholiday » Mon Oct 25, 2010 10:26 am
They do have battery powered ones, that don't require hand pumping. Heard several people saying they work pretty well. My concern would be corrosion, not sure if they can be manually pumped or not. Don't use mine often, though they are invaluable when ya got go.
oldskool
Re: Chemical Toilet
#14 Post by oldskool » Sat Jan 15, 2011 5:18 pm
i find that using a small camping toilet seat that folds up small and stores easy is the best way to go. you use these chem toilets you have to dump them, clean them and handle everybodies mess ! my way- you gotta take a squirt, you put a small bucket under it and then dump it over and rinse it out. need to crap, you put a bag in the bucket you tie it and then put it in the trash. its just that simple and you keep your hands clean!!
