Got the deck boards painted up this week, if it stops raining I will put them on tonight, then carpet and I can really get things moving from there.
Friday before the storm hit, I got the boards on the deck.
Before I put them on, I re-did the winch eyelet support brackets. The old brackets were very thin and buckling from use. You can see the difference in the pic here. A nice CFF member had the material he'd been storing for many years and donated a couple pieces for me.
All boards now installed, just need to put all the screws in, I only tacked it around the edges so far. The remaining should only take me ten minutes though. I hope at the end of the week it will be warm enough to lay the carpet then I can really get it rolling.
New console ordered today, cant wait to get it and start the rebuilding proccess.
Also got my new fence bolts and risers in today. I am ready!!!
So I got the remaining screws in and carpet laid tonight. It now under tarp for 5 days, (keep dry per glue instructions). After that is On!!!!!!!!!!
Got the edge caps back on today, all but the transom area anyways. I am going to have to modify it slightly as the new boards are not the same length back there now. Will start placing the railing and mapping out where some other things go tomorrow.
Ok guys, been a while since the update, but coming along. I got all the rails back on, trim on all four edges and the corner trims back in place. I think I will like the spacers that I bought to raise the rail up. That should make spraying off the floor a breeze. I was also able to knock out the two places in the back where the siding was a little pushed in. If it hadnt been so crazy cold this winter I would have taken time to clean the railing up really well prior to re-instalation, but so be it, I will get that done this week. Having it held tight in place will allow me to scrub it then pressure wash it better anyways. I do have plans repaint the exterior but I have enough money in the project right now, it will be fine cleaned up.
Last week I got the base for the console built. The unit I bought was a little smaller than I hoped, but I couldnt bring myself to spend $800 on the one I wanted. What I built wll give me a seat in the front, with storage under it, and I sealed the whole thing, then put carpet on the base to match the floor. The pics show where I have screwed some scrap wood on the corners to allow it to adhere on the corners better.
Looking forward, weather permitting, to start installing the console pieces, and getting the steering and gauges hooked up. I am crossing my fingers that it will go smoother than I fear after looking at the mess of wires I have for it! LOL
Installing the gas tank, battery selector switch and lighting should be a couple hour ordeal at most, so I COULD be ready to test it out next week some time. Keep your fingers crossed.
Console is about complete. I used a corner trim made of PVC from Lowe's to protect the bottom from being in contact with the wet carpet all the time. Even though I sealed it, I wanted that extra protection. It also gives it a clean look I think. I used clear window silicone then a few galvanized nails to hold it all in place. Will get it installed tomorrow if all goes well.
