A good friend of mine on Hartwell. Has an ole pontoon that stays in the water uncovered year around. He just bought a metal frame that used to have a fabric top. It is the kind that you see a lot of people with metal skins on them instead of fabric. He is thinking about corrugated steel. Are there any better options ? If so please share a link.
Metal top
Re: Metal top
I don't have a metal roof but, here's a link:
http://www.metaliteind.com/canopies.html
My guess is steel is too heavy for that use.
Yamaha Vmax SHO 115HP
New at This
Re: Metal top
My boat has an aluminum roof, same material that truck caps are made out of. Maybe a metal roofing supply house could help locate some. Would also need cross pieces to keep it rigid. Just pop rivet it on
Re: Metal top
My old Starcraft has an aluminum sheet roof on a frame made out of the same square aluminum tubing the fence is made of. It weighs about 100 lbs., and I can put it up and take it down to the fence.
