1992 monark 24' rebuild
Posted: Tue Dec 06, 2011 6:55 pm
I figure I'm close enough to having most of my parts I need, so I might as well start my official rebuild! The boat is a 1992 24' monark, the motor is a 1996 Johnson 112 that I had to have rebuilt. I've had my toon for over a year now but haven't done much to it because rebuilding the motor took up my seat money and then some. My plan is change my current layout to a fishing layout, I going to have fishing seats in all four corners but still retain all my couches and sun deck in between. I'm gonna use a double bimini but it will be mounted so it dosent interfear with casting from the front and rear fishing stations! I plan on using vinyl flooring and building a raised helm stand for a better view for the captian. I'm changing all lights to led and adding led rope lights around the furniture. Some of this I've done as I've had the boat for over a year but I'm gonna start from the beginning! Here she is the day I got her and cleaned her up the best I can!
The interior dosent look as good anymore, when I did my first cleaning I used ALOT of bleach not knowing it would ruin them, plus after the motor blew I was pretty mad and it sat in the Texas sun for a long time uncovered.
You can see the difference in carpet color where it's faded over the years. It's also really thin you can see the backing in a few spots
Here is a pic of the motor running after the rebuild and the trolling motor I got shortly after
