Wash down pump thoughts
Considering adding a wash down pump to my rebuild project. Since I'm going with the woven vinyl I thought it might be nice to spray er down after the kids track sand on the deck.
Anyone have pictures or locations of best place to install?
1998 Godfrey Aqua Patio 24'
190 hp I/O V-6 Mercruiser
Re: Wash down pump thoughts
I bought this one and just get it out when needed. Works great!
http://www.westmarine.com/buy/trac-outd ... --15888928
Tim
Broken Arrow, OK
Lake Tenkiller
2012 JC Sunlounger Sport 25'
Honda 250 powered
2015 Chevrolet 2500HD High Country Duramax powered
Broken Arrow, OK
Lake Tenkiller
Honda 250 powered
I use a bucket on a rope with whatever water I'm floating in.
I am in the process of installing one. Taking a different approach. I'm rebuilding/modifying my new boat to better suit my needs. Part of that was installing a livewell. I mounted a 360 GPH bilge pump on the back of the pontoon. The hose coming off of the pump plumbs into PVC, when the PVC comes through the deck there is a T fitting with a ball valve coming out of the T, and another ball valve shutting off water to the livewell so all of the pressure and volume can go the hose. Honestly I'm not expecting much out of it, I am hoping it will give me enough pressure to rinse surfaces down after scrubbing them. It only cost me maybe $5 to buy the extra parts since I was doing the livewell anyway.
Worth a try... Keep in mind the open impeller as used in most bilge pumps to allow them to run dry without harm prevents them from developing much if any real pressure but should work as long as your not expecting a lot from it....Pontoon Pirate wrote:I am in the process of installing one. Taking a different approach. I'm rebuilding/modifying my new boat to better suit my needs. Part of that was installing a livewell. I mounted a 360 GPH bilge pump on the back of the pontoon. The hose coming off of the pump plumbs into PVC, when the PVC comes through the deck there is a T fitting with a ball valve coming out of the T, and another ball valve shutting off water to the livewell so all of the pressure and volume can go the hose. Honestly I'm not expecting much out of it, I am hoping it will give me enough pressure to rinse surfaces down after scrubbing them. It only cost me maybe $5 to buy the extra parts since I was doing the livewell anyway.
Harbor Freight makes a marine 12 volt pump for around 40 bucks that's rated for 10psi and works well as a wash down pump.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
Suzuki 225DF
