HELP replaced water pump, motor won't go into gear.
Posted: Sun Apr 17, 2016 8:29 pm
2005 Mercury 115 4 stroke. Having a hard time finding info on this particular procedure on this motor. Trans was in N when I took it off. Put it back together and the shifter won't move. After I got home (boat is 20 miles away) I realised that I didn't have the key in the ignition. I don't remember if I could shift gears without the key or not. I read somewhere after the fact that the motor should be in F before the LU is removed, is that so? Is the transmission on this motor actuated by the spline moving up and down or L to R? I did put a pair of vice grips on it and it did pull up. But only felt like there were two positions there, not three. I didn't try turning the shaft but I understand that it should only be turned CCW. Any suggestions? Also as I was putting the LU back in what appears to be gear oil was leaking pretty bad from the motor end of the shift shaft. Couldn't tell 100% it was gear oil as I just changed all of my fluids and they look a lot alike when they are clean. Didn't know if I had busted a seal or what but it was a lot worse with the motor trimmed up and quit leaking when I put the motor back down.
