Reusing old deck screws
Big Fish Little Fish
I am removing the railings and other items on my pontoon to put on a new vinyl floor. The wood is in good shape so I will be using he same deck floor (marine plywood). My concern is that when I go to screw the parts back on the floor the screws will not grip as well as they originally did. I will be going into the same holes. Has anyone had a problem with this? Is this a concern or am I making a problem out of nothing?
Re: Reusing old deck screws
I have not replaced a floor but have reused screws in wood before. I would imagine you could use larger screws. However, I would use some type of quality wood glue on each screw that your going to use if they are the same size or larger.
Lets see how others weigh in on this.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
Since your stripping the deck you could also go over it with a putty knife and some wood filler first so the screws have new material to grip.
Pinawa Bay, Manitoba
