tilted or level ?
Motor tilted or level when toon is on trailer
Tilted
13
39%
Level
20
61%
Total votes: 33
sHan tn
Re: tilted or level ?
#16 Post by sHan tn » Sat Jun 13, 2009 11:16 am
well on a toon if there is enough clearance as to not hit anything then down..... BUT if it has to be tilted to clear then a transom saver should be used...
:drive
1982 Sylvan 24' Toon
50hp Evenruder
my fishin/camping boat
An unarmed man is a subject.
911: Government sponsored Dial-a-Prayer.
When seconds count....Police are minutes away
moregooder
#17 Post by moregooder » Sun Jun 14, 2009 9:15 am
the MOST force your transom is ever going to see is when the boat is coming out of the hole, fully loaded, with 2 kids in the tube at WOT with my mother in law sitting on the port side. now if my transom can take that it will withstand the ultimate forces associated with towing and yes even storage of an elevated motor.
We boat a lot in Branson on table rock, getting to the boat dock down those roads you come across all kinds of driveways some that make the back of a 24' boat trailer drag even with 14" of clearance. keeping the motor up keeps the prop and the skeg out of the blacktop.
If you want to spend your money on a transom saver knock yourself out it your money, just don't tell Obama what comes after a trillion
