water drain in lower unit??
i have a 2001 mecury 75. noticed today with water hose ears that there is water coming out of a small hole on backside of motor down by shaft. is that normal?
Re: water drain in lower unit??
When running your motor has 2 to 3 places water can exit. The so called Pee hole usually to rear and near the bottom of power head (also known as telltale).
Some have low speed or idle where water comes out of a port about 1/2 down the lower leg and the exhaust hub through prop. When under full power this middle port doesn't spill water under most conditions.
Hope this helps
Hope this helps
that sounds like it. i never noticed before but its a small hole on back beside flat ribbed plates on sides.
My 97 Force 75 does the same thing.
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
