Salt Water in center toon
BLUE by you
#1 Post by BLUE by you » Wed Feb 07, 2018 9:53 am
I had a fair amount of salt water penetrate my center toon. I have a small leak near the nose cone. It has drained the toon but should I be concerned before welding it up?
LINK of leak: https://youtu.be/A-sE3FWKnkk
Jimmy
South Bay 925 3.0+ Super Sport / 300 Merc.
West Palm Beach, FL & Smith Mountain Lake, VA
FLOUNDERPOUNDER225
Re: Salt Water in center toon
#2 Post by FLOUNDERPOUNDER225 » Wed Feb 07, 2018 12:12 pm
I would get the bow up high and pull the drain plug on that toon on the aft end, get all of the water out. You should have Schrader valves on your toons, I have a Berkshire (same MFG, forest river) once the weld is completed make sure you pressure test, no more than about 3 PSI. I installed 90 degree adapters on my Schrader valves, make using an air chuck easy, then I have a digital pressure gauge which is very sensitive and accurate at the lower pressure range. spray some soapy water on the area. I had a small weld crack and repair done last week, they said it was fixed, when I tested it myself, it was not. still leaking, so back it went.
tire valve adapter.png (16.06 KiB) Viewed 4535 times
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
BLUE by you
#3 Post by BLUE by you » Wed Feb 07, 2018 12:34 pm
THX... I was told that section of the toon where the leak is...is sectioned off and unaffected by the plugs. It sites in front of my in floor storage locker. So basically water does not run from front to back in the center toon (per Forest River) on my 925.
Jimmy
Jake_Daddy
#4 Post by Jake_Daddy » Wed Feb 07, 2018 3:57 pm
I wouldn't worry if a little bit gets trapped in there. Chemical reactions can only go on for so long on with a fixed amount of ingredients. Think of when you were a kid making baking soda and vinegar volcano's, they didn't react forever only until all the reactive agents have done there thing.
2001-20' Godfrey Sweetwater
1991 Mercury 90hp
Merritt Island, FL
#5 Post by Bamaman » Wed Feb 07, 2018 7:47 pm
Is your boat still under warranty? If so, let the dealer fix it, but double check their work.
BLUE by you
#6 Post by BLUE by you » Wed Feb 07, 2018 8:14 pm
Yep...and the toons have additional warranties.
Jimmy
FLOUNDERPOUNDER225
#7 Post by FLOUNDERPOUNDER225 » Thu Feb 08, 2018 8:12 am
What additional warranty? I'm interested to know what you were told, this area I have on the stern is a recurring issue, I haven't spoke with FR about it, just my dealer.
Pensacola FL
Yamaha F-150
#8 Post by bansil » Wed Feb 14, 2018 4:57 pm
Nothing to add except Blue by you, is a somewhat famous boat on another forum, he is selling it now and it is replaced by skyline...the most pimptastic boat urgh...ship
Google skyline by horizon
BLUE by you
#9 Post by BLUE by you » Wed Feb 14, 2018 7:34 pm
[quote="FLOUNDERPOUNDER225"]What additional warranty? I'm interested to know what you were told, this area I have on the stern is a recurring issue, I haven't spoke with FR about it, just my dealer.[/quote]
LIFETIME warranty on all Aluminum and welding below deck to the original owner.
South Bay Warranty
From Carpet or Vinyl Up — 5 Years (Original Owner) • Decking Material — 20 Years (Transferable Through Decking Supplier) • All Aluminum & Welds Below Deck — Lifetime (Original Owner)
Jimmy
FLOUNDERPOUNDER225
#10 Post by FLOUNDERPOUNDER225 » Thu Feb 15, 2018 5:29 am
[quote="BLUE by you"][quote="FLOUNDERPOUNDER225"]What additional warranty? I'm interested to know what you were told, this area I have on the stern is a recurring issue, I haven't spoke with FR about it, just my dealer.[/quote]
South Bay Warranty
From Carpet or Vinyl Up — 5 Years (Original Owner) • Decking Material — 20 Years (Transferable Through Decking Supplier) • All Aluminum & Welds Below Deck — Lifetime (Original Owner)[/quote]
Thanks!!
Pensacola FL
Yamaha F-150
