gas in the oil
bedwards289
gas in the oil
i have a used 90 h.p mercury 4 stroke efi that i bought recently. i checked the oil level and it was way above the cross hatched area of the dipstick. it also was thin in viscosity and it smelled like gas was in it. my question is how would gas get into the oil system and what kind of repairs am i looking at?
Re: gas in the oil
Hard to say but you must change that oil and filter NOW. Then keep a close check on it before each start and if you are getting gas in oil again take it to your dealer. Gas in the oil will damage the engine very quickly.
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
Re: gas in the oil
Gas in oil in a carbed motor = bad float. Gas in oil in an injected motor = bad injector. Don't run it until this is fixed or you'll be buying a new powerhead after it seizes or throws a rod. Be glad you found it before either happened and take it to a competent tech ASAP.
Re: gas in the oil
Yes, as BMR said. Bad injector, should be inexpensive to fix but don't run motor until fixed.
2007, 2570 Crest LE II
Yamaha F150
Yamaha F150
