Hydrofoil Stabilizer
Would a hydrofoil stabilizer do anything for my boat? Lift, Control, Speed, ETC?
2002 24' Parti Kraft w/90 hp Honda
Boat at Center Hill Lake
Re: Hydrofoil Stabilizer
Probably not unless you have a problem with blow outs.
And he means prop blow outs, not the other kind.margaritaman wrote:Probably not unless you have a problem with blow outs.
"Nauti Weasel"
2005 Beachcomber Islander 26
- BassFrequency
the one i had gave me problems with blow outs. so its banished to the storage garage.margaritaman wrote:Probably not unless you have a problem with blow outs.
but i also have a short shaft and the only part below the logs when running is the skeg
results seem to vary
60HP Evinrude
60HP Evinrude
Hey BF,
Does the female friend say anything about the short shaft?
- BassFrequency
Its not about the lenth of the shaft, Its how much power spins itmargaritaman wrote:Hey BF,
Does the female friend say anything about the short shaft?![]()
i knew someone would catch that
60HP Evinrude
60HP Evinrude
