Problem
tkrein
Re: Problem
#16 Post by tkrein » Thu Jun 24, 2010 7:41 pm
when you say blow out is the prop still spining or is you linkage just adjusted wrong were it actully slips out of gear but you still have the throttle at full or half way. my old johnson motor use to do that if i didnt have the linkage adjusted. just a thought. but the prop would stop turning altogether like you had it in high throttle. have the dealer check that out for you i think you said this is a new boat.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
LTB Racing
Re: Problem
#17 Post by LTB Racing » Fri Jun 25, 2010 4:26 am
Be very careful and check with the manufacturer of your motor as the prop guard may void your warranty...I've never used one but I do know that such devices have been tried by Mercury and none have become even an option with them?? 8)
LTB Racing
Quartershot T3-R Merc 2.5 260
Fiesta 18 Party Barge w/ Twin Evinrude 50's
http://WWW.LTBracing.com
"The great ones practice the basics"
epowell01
Re: Problem
#18 Post by epowell01 » Fri Jun 25, 2010 5:59 am
Thanks all - I'm going to try the plate from the boat manufacturer as soon as it arrives. If that doesn't do the trick, I'm going to lower the motor (one bolt hole left) and see how that goes. The trial and error gets costly hauling things back and forth. I expected a "ready-to-ride" boat given what I paid.
2010 Sylvan 8522 FNC Signature
Yamaha 150
tkrein
Re: Problem
#19 Post by tkrein » Fri Jun 25, 2010 7:11 pm
when its on the trailer lower the motor all the way take a pic straight on the motor get the toons in there post the pic then we can help you with the motor hight.
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
mike
Site Owner
Re: Problem
#20 Post by mike » Fri Jun 25, 2010 8:44 pm
just a thought but have you tried playing with you trim during this situation?
Parasympathetic
Re: Problem
#21 Post by Parasympathetic » Sat Jun 26, 2010 5:56 pm
I''m hearing him say when it starts slipping or whatever, it won't go forward until he stops and goes into reverse. So that should eliminate trim or blowout. And it happens only when he is running through vegetation. So, it seems to happen when there is a load on the prop. Could this be a spun or slipping hub? Or, like previous post said, slipping out of gear.
Interesting anyway............... :donno
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
WaltF
Re: Problem
#22 Post by WaltF » Tue Jun 29, 2010 12:57 pm
Wild ass guess...
Is he wrapping weeds around the prop and it slows down, so when he hits reverse, they spin back off?
Colorado Springs, CO.
mike
Site Owner
Re: Problem
#23 Post by mike » Tue Jun 29, 2010 12:58 pm
Something tells me this guy needs a set of TAPFINS!! They are so good, fix problems unknown.... :nana :happy :thumbsup
Parasympathetic
Re: Problem
#24 Post by Parasympathetic » Tue Jun 29, 2010 9:18 pm
mike wrote:Something tells me this guy needs a set of TAPFINS!! They are so good, fix problems unknown.... :nana :happy :thumbsup
or rosie odonnel, she could eat the vegatation off the prop.
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
GXPWeasel
Re: Problem
#25 Post by GXPWeasel » Wed Jun 30, 2010 6:15 am
Very interesting problem. This plate thing that the dealer is talking about, is it just a flat plate that goes directly behind the prop, like a trolling device? If so, I don't see how that will fix your issue. My bet is on the slipping out of gear, or slipping hub. Every time I've ever heard of prop blow out, the problem can be fixed easilly by trimming down, slowing down, or turning the motor back straight. I've never heard of someone having to stop, and reverse before the problem is fixed. Good Luck to you, and let us know what you find out. Lot's of good people and info. on here, so hopefully the fixing options keep coming. :biggrin2
"Nauti Weasel"
2005 Beachcomber Islander 26
LTB Racing
Re: Problem
#26 Post by LTB Racing » Thu Jul 01, 2010 3:46 am
Wild ass guess...
That's exactly whats going on....when a prop gets wrapped in weeds it creates turbulent water and air pockets...the air pockets cause the prop to ventilate and lose its grip on the water. When he slows down and hits reverse it gets the weeds off and he can go again.
LTB Racing
