KConJacomo
#1
Post
by KConJacomo » Sat Jul 31, 2010 11:07 pm
Out on the water and I mixed some gas/oil. Then thought I'd pour a few ounces of oil in the gas tank like an idiot. Didn't want to have too little oil.
Engine started and ran for about one minute, then died and wouldn''t start. New plugs didn't fix it. Plugs smelled more like clean oil than gas. I poured premix into a cylinder and engine fired for a second. Figuring the oil is blocking the fuel somehow. Ideas?
Engine is a 35HP Evinrude from 1984. You guys think I just need to pull the gas lines off and blow them out? Or does the fuel filter/ system need attention? Any insight is appreciated.
This was a good learning experience for getting towed and swimming the boat to the ramp.
78' Lowe 24' Pontoon with mid 80's seats and 35HP Evinrude.
Enjoying Jacomo.
Post
by lakerunner » Sun Aug 01, 2010 6:26 am
Your motor uses a 50/01 oil to gas ratio. That should be 16oz per 6 gallons of gas. Sounds like you added to much oil. Dump the gas and start fresh
dockholiday
#3
Post
by dockholiday » Sun Aug 01, 2010 8:08 am
probably will need to clean the fuel lines. the reason it ran for a minute or so was it was burning the untouched gas in the line until it hit you mix. not sure but would not hurt to install a new filter.
KConJacomo
#4
Post
by KConJacomo » Sun Aug 01, 2010 8:46 am
Going today to put in fresh premix. Thanks guys.
Enjoying Jacomo.
crspang
#5
Post
by crspang » Sun Aug 01, 2010 11:18 am
I'm not understanding your explanation. How much "extra" oil did you add?
If you only added a few ounces extra then that would NOT cause your engine to "all of a sudden" not start. Just adding a few ounces of oil wouldn't even cause the plugs to foul. I suspect you have some other issue with fuel delivery, ie carburetors.
KConJacomo
#6
Post
by KConJacomo » Sun Aug 01, 2010 2:04 pm
crspang wrote:I'm not understanding your explanation. How much "extra" oil did you add?
2-3 ounces tops. Might not jack with it tonight, I'm so worn out from this long week.
Enjoying Jacomo.
Heatman
#7
Post
by Heatman » Sun Aug 01, 2010 4:04 pm
That little of extra oil shouldn't cause it not to run. During new engine breakin you run alot richer on the oil than that.
Sheridan, Indiana
#8
Post
by badmoonrising » Sun Aug 01, 2010 5:44 pm
Yep...too little oil = a problem. Too much, rarely causes any issues.
Post
by lakerunner » Sun Aug 01, 2010 7:38 pm
Is it possible you poured the oil in and didn't mix it? and then started motor only to pull mostly oil through carbs. You did say they were oily
KConJacomo
#10
Post
by KConJacomo » Sun Aug 01, 2010 8:59 pm
lakerunner wrote:Is it possible you poured the oil in and didn't mix it? and then started motor only to pull mostly oil through carbs. You did say they were oily
Yea, I didn't mix it. Big mistake.
I pulled the fuel filter off while on the water and think I lost a seal. I can't get the filter to seal right now. Tried to fire the motor tonight and the gas tank was empty. I had just filled it before it quit working. So the gas has leaked out. Maybe there was a siphon and it all leaked out the filter seal.
Got to find a good marine parts store around here. Anyone local have suggestions?
Enjoying Jacomo.
FloterBoter
#11
Post
by FloterBoter » Mon Aug 02, 2010 5:26 pm
too much oil should just put out blue smoke and help speed up global warming.
bring it on, i freakin hate winter.
KConJacomo
#12
Post
by KConJacomo » Tue Aug 03, 2010 4:12 pm
Tried to get it running today with no luck. My dealer was out of stock for the engine repair manual. Anyone got advice for how to clean the carbs? Looks like they are near the crank end and under the flywheel. Bit intimidating without a repair manual. I can't even tell where the exhaust and air intake are on the engine still. LOL Any help is appreciated forum, love you guys.
Enjoying Jacomo.
crspang
#13
Post
by crspang » Tue Aug 03, 2010 6:46 pm
Check with your local library, they probably have a Seloc manual available.
KConJacomo
#14
Post
by KConJacomo » Tue Aug 03, 2010 8:03 pm
crspang wrote:Check with your local library, they probably have a Seloc manual available.
Great idea thanks!
Enjoying Jacomo.
PRINTMAN
#15
Post
by PRINTMAN » Wed Aug 04, 2010 2:03 pm
NIEGHBOR JUST HAD HIS 50 EVINRUDE IN THE SHOP THEY SAID HIS OIL INJECTOR FOULED UP AND PUMPED TO MUCH OIL IN WOULDNT START CLEANED THE FUEL LINES TANK AND HEAD FIRED RIGHT UP I THOUGHT THEY WERE KIDDING HIM BUT IGUESS NOT SO I DISCONNECTED THE INJECTOR AND WILL JUST MIX IT MYSELF GUESS THATL'S THE REASON YOU CANT BUY PARTS FOR A MECURY INJECTOR SYSTEM
