noise
Drago
Re: noise
#16 Post by Drago » Thu Apr 16, 2009 9:14 pm
If you get the chance to demo a few, check the vibration levels at low to mid speeds. I found the Premier with a 225hp i/o and Volvo Penta duo drive to have much more vibration than any of the 225hp outboards we tested. Granted, we only drove two i/o boats, the Premier and a 300hp JC tritoon. The JC did not have the vibration but was a much quicker boat. All the outboards were 225hp - Honda, Yamaha, Suzuki, and Mercury Optimax - all smooth as glass - and quiet too.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
beermunk
Re: noise
#17 Post by beermunk » Fri Apr 17, 2009 5:41 am
Drago wrote:If you get the chance to demo a few, check the vibration levels at low to mid speeds. I found the Premier with a 225hp i/o and Volvo Penta duo drive to have much more vibration than any of the 225hp outboards we tested. Granted, we only drove two i/o boats, the Premier and a 300hp JC tritoon. The JC did not have the vibration but was a much quicker boat. All the outboards were 225hp - Honda, Yamaha, Suzuki, and Mercury Optimax - all smooth as glass - and quiet too.
Agreed - there's some vibration from the engine at low RPM's on the Mercruiser 3.0l on our boat (22' suntracker I/O). I think it's because the motor is mounted more into the frame of the entire boat, and on a pontoon there's a lot more to vibrate when it comes to railings, doors and biminis.
I'll be fixing all of that today though with some little sticky rubber grommets that I'll put wherever something is vibrating and clinking.
_________________________
Buy the ticket - Take the ride.
- H.S.T.
Re: noise
#18 Post by badmoonrising » Fri Apr 17, 2009 6:11 am
Yep, I/Os + aluminum boats = vibration, especially the 3.0. Best you can do is what Beermunk said. I put rubber strips on all the storage bins on the Starcraft and that took care of 90 percent of the vibration noise. The PC, it's not an issue, everything is carpeted, even the engine compartment.
beermunk
Re: noise
#19 Post by beermunk » Fri Apr 17, 2009 6:54 am
badmoonrising wrote:Yep, I/Os + aluminum boats = vibration, especially the 3.0. Best you can do is what Beermunk said. I put rubber strips on all the storage bins on the Starcraft and that took care of 90 percent of the vibration noise. The PC, it's not an issue, everything is carpeted, even the engine compartment.
badmoonrising - where and what did you buy for your rubber strips? I know exactly what I need to purchase but I can see walking into the hardware store and not being able to explain what it is I need.
Rubber dampening with 3M sticky backing... something like that.
- H.S.T.
Re: noise
#20 Post by badmoonrising » Fri Apr 17, 2009 7:01 am
I got mine at our local ACE True Value. Forget what exactly they call it though, but it was in the same section as storm doors and is one sided black foam tape.
beermunk
Re: noise
#21 Post by beermunk » Fri Apr 17, 2009 7:07 am
badmoonrising wrote:I got mine at our local ACE True Value. Forget what exactly they call it though, but it was in the same section as storm doors and is one sided black foam tape.
Sweet thank you I'll look there.
- H.S.T.
1badtoon
Re: noise
#22 Post by 1badtoon » Wed Apr 22, 2009 5:20 am
It's weather stripping
D.J.and Stacy James
Searcy AR
2008 Premier Grand Majestic 235 LTD
36"PTX
Suzuki 250 SS
Greers Ferry Lake, AR
