Adding lift strakes
Crab Island Cruiser
Re: Adding lift strakes
#16 Post by Crab Island Cruiser » Mon Jun 15, 2015 11:49 am
I looked at a sun tracker 24' triton yesterday. I was surprised to see the strakes stopped a few feet shy of the back of the log.
07 22' Sun Chaser
Yami F115 power
low and slow
ToonGuy
#17 Post by ToonGuy » Mon Jun 15, 2015 1:30 pm
Most toons will not have strakes on the outside of the outer tubes. Sometimes on 2-log pontoons, to get the lift needed they put strakes on the inside AND outside, but stop them on the outsides 2/3 or so from the front nose cone. The reason is because generally strakes on the outside negatively effect your cornering performance. Cutting them "short" on the outside helps to keep the toon from digging in the corners.
BobG
#18 Post by BobG » Mon Jun 15, 2015 2:10 pm
You just need to add some of those...uh...what the heck are they called...Smack Fins? Thump Fins? Whack Fins? Shoot I can't remember... :devillol
Crab Island Cruiser
#19 Post by Crab Island Cruiser » Mon Jun 15, 2015 5:26 pm
ToonGuy wrote:Most toons will not have strakes on the outside of the outer tubes. Sometimes on 2-log pontoons, to get the lift needed they put strakes on the inside AND outside, but stop them on the outsides 2/3 or so from the front nose cone. The reason is because generally strakes on the outside negatively effect your cornering performance. Cutting them "short" on the outside helps to keep the toon from digging in the corners.
Good info! I discussed inside mounting or outside mounting with the fab guy today. I'm going to put them on the inside of the toon.
He has done the install on the outside of 22 footer a year or so ago and the guy is tickled pink. lol
He only has strakes on the outside.
07 22' Sun Chaser
Yami F115 power
low and slow
rancherlee
#20 Post by rancherlee » Tue Jun 16, 2015 3:44 am
Also, As I found out, strakes NEED to be cut short on a center tube if they are negative angle. I did my own strakes and ran them front to back on my center tube and they trap a decent amount of AIR and feed it to the prop. With the strakes ending 2-3 feet before the transom the air bubbles have time to escape to the sides and clean water gets to the props. Many early tritoons had strakes all the way back, MOST now stop them a foot or 2 short of the end, especially on the center. My grandpa's neighbor at the lake has an older twin tube with full length strakes on both sides and it a good work out trying to get that thing to turn at speed and it leans hard the WRONG way while turning because the outer strake grabs hard.
Waterlogged
#21 Post by Waterlogged » Tue Jun 16, 2015 9:45 am
I don't know why the strakes end at the point they do, but the boat seems to plane out good on them the way they are.
Glenn
2008 Mercury 115 4 stroke
Crab Island Cruiser
#22 Post by Crab Island Cruiser » Thu Jun 18, 2015 2:44 pm
How wide should they be? 3" 4" 6"
That's the only thing left for me to figure out. I may be able to get it in the shop in a little over
a week to get them installed.
I decided on strakes on the inside of the toons at 14' long.
Looks like it's going to cost about $2200.
07 22' Sun Chaser
Yami F115 power
low and slow
ron nh
#23 Post by ron nh » Thu Jun 18, 2015 3:03 pm
you should absolutely see what size sun chaser put on that boat. i guaranty they tried all different sizes before they put it on the market. learn from there research. my friend spent thousands a few years back adding strakes, he guessed and got no better performance. actually turned worse a high speed.
Crab Island Cruiser
#24 Post by Crab Island Cruiser » Thu Jun 18, 2015 3:15 pm
ron nh wrote:you should absolutely see what size sun chaser put on that boat. i guaranty they tried all different sizes before they put it on the market. learn from there research. my friend spent thousands a few years back adding strakes, he guessed and got no better performance. actually turned worse a high speed.
To the best of my knowledge, Sun Chaser did not use strakes on the 07. Sun Chaser told my local dealer they for sure did not use a center log on any 07s. I asked the dealer about strakes and he suggested I find a local welder/fab shop to do the work.
The fab shop i'm using did a 22' twin toon with 115 merc approx 2 years ago and the guy is tickled pink about the results. He claimed he picked up 8 mph from 1 strake on the outside of each log.
07 22' Sun Chaser
Yami F115 power
low and slow
ron nh
#25 Post by ron nh » Thu Jun 18, 2015 3:20 pm
There goes that idea.
willy13
#26 Post by willy13 » Thu Jun 18, 2015 5:40 pm
The one I measured the other day was 6 inches wide. I measured because I have also been thinking about doing what your doing. Good Luck!!!
Crab Island Cruiser
#27 Post by Crab Island Cruiser » Thu Jun 18, 2015 6:32 pm
ron nh wrote:There goes that idea.
No worries. :drink4
07 22' Sun Chaser
Yami F115 power
low and slow
Crab Island Cruiser
#28 Post by Crab Island Cruiser » Thu Jun 18, 2015 6:35 pm
willy13 wrote:The one I measured the other day was 6 inches wide. I measured because I have also been thinking about doing what your doing. Good Luck!!!
I've seen them from 3" to 6". I'm wondering if the 6"s would put a lot more stress on the tubes compared to the 3 inchers.
I bet i'll be alright, but i'm trying to cover as much as possible before I pull the trigger.
07 22' Sun Chaser
Yami F115 power
low and slow
willy13
#29 Post by willy13 » Fri Jun 19, 2015 6:38 am
Personally, I am not worried about any extra stress put on the tubes from adding lifting strakes. My only worry is causing a leak. But since you found someone who has done this before, that is not a concern for you. I was thinking about attempting it myself since I have had no luck finding someone who has done this before in my area.
Crab Island Cruiser
#30 Post by Crab Island Cruiser » Wed Jul 01, 2015 2:59 am
Soooo, the lift strakes might not materialize right away. I found a place in MO that sells pontoon logs and can customize them.
I can get a full center log with transom and strakes for $1700, but I have to drill the holes for my motor to mount. Not to crazy about that.
Or I can get a 16' log with strakes for $1000 to use as a pony tube.
What do you guys think would be the best option?
The place is 11 hours away from me and it would be way easier to transport the 16 footer. Not to mention quite a bit cheaper.
My toon is an 07 Sun Chaser 22' with F115 Yami
07 22' Sun Chaser
Yami F115 power
low and slow
