What gauges do you find a necessity to have?
Re: What gauges do you find a necessity to have?
FogHorn has been Pm'd
Hey, I was wrong about assuming the Simrad would track fuel usage since Yamaha outputs fuel rate. Requires a fuel data manager added to the network, about $90 to do the job. It just picks up the fuel rate and puts usage data out....you'd think that would already be built into devices that are able to display fuel rate but hey it gets them another $90. You probably already looked into it, might not even be required with what you're setting up....Navico/Lowrance/Simrad need it but I don't think Garmin does.teecro wrote: ↑Fri Aug 02, 2019 3:45 amThe unit I'm currently using is a stand alone inline fuel flow meter that links via Bluetooth with my phone...
The WiFi unit I'm bringing online later links with the Yamaha and I'm expecting to see RPM, Volts, Oil Pres, Water Temp, Fuel Flow and Eng Hours displayed on my phone screen. I'm unsure but MPH may also come up as I'm told that the WiFi module has a GPS ant built in, we shall see. I know I can expand the network and eventually read the fuel tank too...
My Simrad is connected to my Yamaha 150 with an NMEA network and I get Gallons Per Hour shown on my Simrad. What does the fuel data manager add?Steiner wrote: ↑Thu Aug 01, 2019 3:03 pm
It'll get you actual fuel used for trip, season, lifetime. They're supposed to be really accurate. I believe if you set your vessel info up with tank size it'll also show fuel remaining, range, etc. if you want to reset that stuff after every fill up. It is also a storage device for that info rather than storing it on the Simrad. Found an open box one on ebay for $65. They come with a T so if your backbone is easy to access like mine (just under the helm) it should take about 90 seconds to install.....but probably take a weekend to figure out all the stuff on the Simrad to display what you want. Garmin does it already without requiring the dongle. It's no longer called the EP85 but is its replacement if you're interested in looking into it and see that referenced anywhere.steve1313 wrote: ↑Sat Aug 17, 2019 2:57 amMy Simrad is connected to my Yamaha 150 with an NMEA network and I get Gallons Per Hour shown on my Simrad. What does the fuel data manager add?Steiner wrote: ↑Thu Aug 01, 2019 3:03 pm
https://ww2.simrad-yachting.com/Root/Si ... n-Note.pdf
https://www.hodgesmarine.com/Navico-Fue ... 22-001.htm
http://www.bbcboards.net/showthread.php?t=849730
Thanks for the info and the links. I ordered the data manager from Hodges for $82. Cheap enough add-on to buy just to play around with!Steiner wrote: ↑Thu Aug 01, 2019 3:03 pm
You bet. I gotta learn to fiddle with it while still tied to the dock....that Simrad can be worse than texting while driving.
That's so true. It's has one of the most un-intuitive UI's that I've used in a while. I had a Garmin before and it was much easier to use.
I wish I had a gauge that would tell me which direction my motor is pointed. It is a tight squeeze to get my boat on and of the lift and I keep having to stand up to see what angle my motor is at. I like lots of gauges, Tack, depth, gps, temp, oil pressure, voltage, trim but none are really necessary except the standard alarm buzzers.
'03 F250 Powerstroke
Installed it...if you can even call it that.... yesterday and went out a little tonight. Pretty intuitive once you find where everything is to set up. You can add a fuel gauge and/or fuel remaining to your screens. Pretty easy to reset to full when filling the tank, or it'll even let you just type in how many gallons you put in if you use a can. Will see how accuracy is after the weekend.
Reported usage was 7.9xx gallons, refill was 8.6xx gallons so about a 10% error. There is a calibrate function on the refuel screen where it shows you gallons reported and you input actual gallons to refill but it errored on me, I think because I'd already checked "set to full" before noticing the calibrate button.Steiner wrote: ↑Fri Aug 23, 2019 5:58 pmInstalled it...if you can even call it that.... yesterday and went out a little tonight. Pretty intuitive once you find where everything is to set up. You can add a fuel gauge and/or fuel remaining to your screens. Pretty easy to reset to full when filling the tank, or it'll even let you just type in how many gallons you put in if you use a can. Will see how accuracy is after the weekend.
Figured it out after RTFM....can only do the calibrate function if running a Navico flow sensor.Steiner wrote: ↑Wed Aug 28, 2019 9:28 am
My fuel management system is "fill it up before I go out."
This WOULD NOT be my approach if I boated on bigger waters or had a bigger motor like you guys. Living on a little 18 mile long lake and running a small motor has some advantages. With only 24 gallons, I have not been able to run it out in a single outing, but I carry a standard five gallon "get me home" gas can to be sure.
For me, cruise is just under 5 GPH at 18-20 MPH, depending upon load. Party in slow motion.
Hey, me too. We only get to do a weekend at a time and mostly just load up the dogs, hit an island, come back, repeat. Trailer down on a Friday, trailer home on Sunday and hit the Lake Shop on the way home to top off the tank along with stabilizer so every time we hit the water no matter when it might be we know it's got a full tank of stablized fuel. Also helps to keep from getting abused at the marina. There have literally been weekends back when I had the 90 that we only used three gallons but it still got topped off. Now since getting the 200 we do ride around a bit more since cruise speed jumped up...gotta dry the dogs off somehow. So far we only get to spend a full week down at the lake once a year, and I'll hit the marina after a few days to top off just to be safe.
BTW, amazing times we live in now where a 115 is a "small motor".
