Straked 21' 90HP Sutracker. What performance can I expect?
wrd1972
#1 Post by wrd1972 » Wed Aug 10, 2011 1:52 am
I am looking for a faster than average pontoon boat and have my eye on a 2008, 21 foot, factory straked Suntracker PB. Most non straked boats like this can make 20MPH but I want to know the realistic performance of the straked boat.
Anyone have any experience with straked boats ?
hyper
Re: Straked 21' 90HP Sutracker. What performance can I expect?
#2 Post by hyper » Wed Aug 10, 2011 6:05 am
My 24 foot 50hp mercury powered pontoon will run 19mph with 4 people on board, full of gas and with a 12 pitch prop at 5100 RPM's no stakes. I would think you should be around 24 to 27 mph
2003 50HP Elpto 2 stroke
Mrtoler
#3 Post by Mrtoler » Wed Aug 10, 2011 7:51 am
If it has the NV performance logs you can probley expect 34-40!
2006 dodge ram quad cab
Crosby Texas
#4 Post by Bamaman » Wed Aug 10, 2011 9:02 am
Remember that straked boats cannot be marginally powered. It takes horsepower to get'em up on plane--preferably the largest motor the specs allow. Then, they'll run pretty fast.
Good luck finding such a boat.
wrd1972
#5 Post by wrd1972 » Wed Aug 10, 2011 9:16 am
Thanks for the reply. Suntracker showed the max reccomended motor for the straked boat in question was the 90HP Merc which again it already has. I will assume that with that boat, it performs as they intended. But I can see where a bigger motor could do even better things. :mrgreen:
lakerunner696
#6 Post by lakerunner696 » Wed Aug 10, 2011 9:45 am
From what I have seen on our lake you will run about 25 with strakes lifting bow and rear plowing because yo don't have enough power to get rear up also
2008 F150 Lariat Super Crew
Haul Rite trailer
hyper
#7 Post by hyper » Wed Aug 10, 2011 9:55 am
Just about what i said, I agree
brumbyvet.1044
#8 Post by brumbyvet.1044 » Wed Aug 10, 2011 1:53 pm
Lakerunner, I don't know about the boats on your lakes but believe me, if the boat is running the highest hp that the boat is rated for it should do fine with strakes. I have nothing but praise for the SunTrackers and mine runs fine with the 90 that it is rated for. I've outrun many of the three loggers with 150 hp motors. :biggrin2 I was outrun by a Extreme Tri Hull with a 420 hp inboard however. :(
Back to the OP, if your propped right you can expect 35-36 mph with up to 6 people (no heavyweights) onboard. With a SS performance prop I've seen 39.2 mph with 2 in the boat.
Garmin 430S
Cherokee Lake, TN
shadow-13x
#9 Post by shadow-13x » Wed Aug 10, 2011 3:35 pm
brumbyvet.1044 wrote:(no heavyweights) onboard.
I resemble that comment.
this space for rent
wrd1972
#10 Post by wrd1972 » Wed Aug 10, 2011 3:37 pm
brumbyvet.1044 wrote:Lakerunner, I don't know about the boats on your lakes but believe me, if the boat is running the highest hp that the boat is rated for it should do fine with strakes. I have nothing but praise for the SunTrackers and mine runs fine with the 90 that it is rated for. I've outrun many of the three loggers with 150 hp motors. :biggrin2 I was outrun by a Extreme Tri Hull with a 420 hp inboard however. :(
It looks like you have the exact same spec'd boat I am looking to buy and I am excited to hear your personal results. My ultimate goal is to have it make 30MPH with about 4 on board. If it takes a different prop to do it, no big deal. I am no expert on these boats but it seems that from what I have found on the net, these straked NV log boats go significantly faster than your conventional boat. Even if it simply went 25 on the GPS, I would not be disappointed considering every 21" 90HP toon I have been on only made 20MPH. Guess I will just have to wait and see.
What spec aftermarket prop would provide optium performance in your opinion.
hyper
#11 Post by hyper » Wed Aug 10, 2011 4:57 pm
After you get the boat you want will you please come back to this forum and let us know what it really runs. It takes more to make a pontoon run than most know.
lakerunner696
#12 Post by lakerunner696 » Wed Aug 10, 2011 9:53 pm
We have 3 or 4 on our lake with the 90 Merc and I have yet to one in full plane at full throttle. I just don't think a 90 is enough for a boat with strakes to get it up all the way.
But they might not have it trimmed or loaded right.
Haul Rite trailer
wed
#13 Post by wed » Thu Aug 11, 2011 8:09 pm
My experience is that a NV (straked logs) equipped Tracker Fishing Barge 21 will run 38 - 39 MPH (GPS) when equipped with a properly setup 90 HP motor. I run a 13.25 X 17 prop @ 5800 RPM to get 38 - 39 MPH. This is with two adults on board, full tank of gas and about 50 pounds of extra weight. With six adults on board it will still run around 33 to 35 MPH. Note that it is very trim sensitive and best speed is trimmed nearly flat. I also have a 13.75 X 15 prop that I use when operating with higher loads. This prop will still move the boat to about 35 MPH and will hit the rev limiter if pushed.
I originally had a 60 HP on it and was not satisfied with the performance. More than two people and it could not utilize the strakes. Top speed was about 30 MPH with two adults on board. Thank goodness the dealer was willing to let me trade in the 60 and difference for a 90.
Tracker got this package right and then stopped making it .... go figure.
2007 GMC Sierra
wrd1972
#14 Post by wrd1972 » Fri Sep 02, 2011 6:28 pm
Woohoo. Finnaly got the boat and it does 33mph top closed and 31 top open with 2 adults, 2 kids. It feels like any other pontoon up to about 23mph then it starts to plane and accelarates even quicker to top speed. Needless to say I am very pleased.
jlbutl
#15 Post by jlbutl » Fri Sep 02, 2011 6:37 pm
Nice! Excellant find, hope you enjoy her. I finally got my 2011, 22' non straked up to 26 mph WOT last weekend. Just me on it, bimini down, light chop. Sure wish I could break 30!
2011 SunTracker Party Barge 22 Regency
2011 Mercury 90hp EFI 4-Stroke
Pea Ridge, FL
