Marine Battery
OldGrumpy
Marine Battery
#1 Post by OldGrumpy » Mon Aug 15, 2011 4:28 pm
What brand of marine battery is the best?
Bennington 2275 RLi
Yamaha 115 4 Stroke
Lake James NC
lakerunner696
Re: Marine Battery
#2 Post by lakerunner696 » Mon Aug 15, 2011 5:53 pm
I use AutoZone Marine Starting/Deep Cycle. They run around $70.00 with core and carry a 2 year full replacement.
2008 F150 Lariat Super Crew
Haul Rite trailer
GregF
Re: Marine Battery
#3 Post by GregF » Mon Aug 15, 2011 6:10 pm
Are you looking for a starting battery or a "house"/trolling battery?
Pontoons are really not that tough on batteries (they don't pound like a V hull) I use a Wal-Mart car battery for starting my motor, the only reason I have one. You can take one back to Wal-Mart with a bullet hole in it and they will give you a new one within 2 years. I usually get 4 or 5 out of one.
1974 Harris
70 HP 4 stroke EFI Yamaha
Ron Burgundy
Re: Marine Battery
#4 Post by Ron Burgundy » Mon Aug 15, 2011 6:51 pm
I would vote for Optima as being the best, but it's probably overpriced for most applications.
Re: Marine Battery
#5 Post by Bamaman » Mon Aug 15, 2011 7:02 pm
Deep cycle marine batteries are infamous for short life spans. A regular deep cycle battery is $80 at Autozone vs. $229 for an Optima deep cycle battery.
I use car batteries for my boat/motor, and they've been lasting 3-5 years. They're less expensive than deep cycle batteries.
It's best if batteries are removed in the Fall and brought inside until Spring. But, don't store them on a concrete floor (for some unknown reason.)
I keep a Battery Tender on my WaveRunner all Winter, and also use it on my other batteries to do a slow multi-day full charge.
GregF
Re: Marine Battery
#6 Post by GregF » Mon Aug 15, 2011 7:17 pm
I have heard the bad reputation about batteries on concrete floors went away when they stopped using the hard rubber case but I still put them on a block of wood.
It will not take much acid migrating down the side to "ring" the floor.
1974 Harris
shadow-13x
Re: Marine Battery
#7 Post by shadow-13x » Mon Aug 15, 2011 8:00 pm
Bamaman wrote: But, don't store them on a concrete floor (for some unknown reason.)
I had a friend tell me the same thing for my car battery I had on trickle charge. something about the ground having a different polarity and will cause the battery to discharge. he told me put it up on wood since it doesnt conduct electricity. he sounded like he was serious. IDK
this space for rent
GregF
Re: Marine Battery
#8 Post by GregF » Mon Aug 15, 2011 8:21 pm
I have heard a lot about the discharge thing but the problem with damaging the floor seemed a lot more plausible. These days with the plastic battery case any discharge issue sounds like urban legend even if it was true of the rubber cases.
1974 Harris
chill'nthemost
Re: Marine Battery
#9 Post by chill'nthemost » Mon Aug 15, 2011 9:39 pm
GregF wrote:I have heard a lot about the discharge thing but the problem with damaging the floor seemed a lot more plausible. These days with the plastic battery case any discharge issue sounds like urban legend even if it was true of the rubber cases.
agreed
BiXLL
Re: Marine Battery
#10 Post by BiXLL » Tue Aug 16, 2011 4:51 am
why would rubber discharge on concrete but not plastic? Rubber is as good if not better insulator then plastic is???????
2013 South Bay 522CR tritoon
2013 Yamaha 115
Woody
Re: Marine Battery
#11 Post by Woody » Tue Aug 16, 2011 5:54 am
GregF wrote:.....These days with the plastic battery case any discharge issue sounds like urban legend even if it was true of the rubber cases.
Yep. I keep my batteries on the concrete floor every winter, just as I have for many years. It will do NOTHING to harm the batteries these days.
2014 Benny (Until I find a replacement for my totaled JC Tritoon)
OldGrumpy
Re: Marine Battery
#12 Post by OldGrumpy » Tue Aug 16, 2011 3:01 pm
Thanks for all the help. Today I was able to have the battery tested and it just needed charging so now I need to look for a jump start box.
Bennington 2275 RLi
Yamaha 115 4 Stroke
Lake James NC
tntooner
Re: Marine Battery
#13 Post by tntooner » Fri Aug 19, 2011 4:04 pm
some jump start boxes need the battery that is being jumped to have enough voltage to pull in a relay on the jump box. I have an old one like this, so I have got one now that has a switch on it. :)
MH Hawker
Re: Marine Battery
#14 Post by MH Hawker » Sun Aug 21, 2011 8:58 pm
I have tryed about ever brand made at one time or another and most just plain wont last more than 2 years car or marine, but with one exception, i bought a hybrid house/starting from K mart , a delco it was something like 125.00 10 years ago and lasted all most 8 years,was very heavy, i had gotten tired of running out of juce fishing at nightand bought thier top of the line ,, and like most things that work they stopped making it , i was in a bit of a huiire to get my boat up and running , so i got a interstate marine hybrid ,thier decent but around 4 years is all you will get out of one, i should of spent the time tracking down a delco , thier sealed and you never have to add water or worrie over a acid leak
Heatman
Re: Marine Battery
#15 Post by Heatman » Mon Aug 22, 2011 2:10 pm
lakerunner696 wrote:I use AutoZone Marine Starting/Deep Cycle. They run around $70.00 with core and carry a 2 year full replacement.
I just bought one of those myself. The guy that rang me up said I really didn't have to worry about keeping the receipt, they can just look it up by my phone # if I have a problem.
Last summer I went to Walmart and bought their largest battery for my trolling motor. Took it home, put it on the charger and it said BAD BATTERY! Took it back and they tested it, bad cell. They didn't have another one and didn't want to give me a refund 2 days later! They wanted me to wait until they got another in! F-that! Didn't take long for me to convince them to give my money back! Man, I hate that place!
Sheridan, Indiana
