Page 1 of 2
Storage ideas?
Posted: Tue Jan 10, 2012 9:56 am
by captainjack
Storage idea's thought this may be a good idea to see what ideas u guys have on any ideas from tackle to storage containers to anchors. At cabelas I found these bottom bouncer bags to keep them organized. For crank bates I found the 8" special mate boxes at Franksgreatoutdoors.com for 50 bucks they work great. I wish someone made a prop box an anchor box like a cordless drill plastic case to make them less damaging in sliding around under a seat. For my little companion grill by New holland after going to the stores I found a tub at k mart that fits it awesome! So if you guys have any great ideas let the rest of us know.
Re: Storage ideas?
Posted: Tue Jan 10, 2012 10:46 am
by GregF
I like a 50 cal ammo can for a tool box. It is gasketed so the tools stay dry.
Re: Storage ideas?
Posted: Tue Jan 10, 2012 11:35 am
by dockholiday
the cheap pistol cases make good storage containers. Doskocil and plano are around 10 bucks for the double and if you don't need the foam just remove for more area.
something like this........think even walmart has em
http://www.gunaccessoriesusa.com/guncas ... ncases.htm
Re: Storage ideas?
Posted: Wed Jan 11, 2012 3:58 am
by ROLAND
we use an old milk crate to store our mushroom anchors... works well... let's the water run off but yet keeps the anchors secure and out of the way when not in use...
Re: Storage ideas?
Posted: Wed Jan 11, 2012 8:44 am
by Ron Burgundy
A 10 gallon paint bucket is one of the most used thing on my boat. I throw in my squid and shrimp bait so when the ice melts it dosen't get all over the deck. I toss in my anchor after pulling it up to keep sand off the deck. It's also good to keep small baitfish before I cut them up so they don't take up room in the livewell.
Re: Storage ideas?
Posted: Wed Jan 11, 2012 2:03 pm
by captainjack
Ron Burgundy wrote:A 10 gallon paint bucket is one of the most used thing on my boat. I throw in my squid and shrimp bait so when the ice melts it dosen't get all over the deck. I toss in my anchor after pulling it up to keep sand off the deck. It's also good to keep small baitfish before I cut them up so they don't take up room in the livewell.
Thought this would blow up a bit more than it has. What do u guys do with your ropes anchor,ski,docking?
Re: Storage ideas?
Posted: Wed Jan 11, 2012 2:59 pm
by GregF
I hang lines on the rail so the dry quickly and are easy to grab when you need one.
Re: Storage ideas?
Posted: Wed Jan 11, 2012 11:19 pm
by lakerunner
My docking ropes stay attached to boat and over the rails and tucked between seats. My anchor I use a plastic milk crate also. Coil the rope then lay anchor on top. when you throw anchor rope flows out and when pulled in the crate keeps it loose and again the anchor holds it down.
Re: Storage ideas?
Posted: Thu Jan 12, 2012 9:20 am
by Mrtoler
On page 38 of general toon discussion texaspontoon had some good ideas on this subject, I'd post the link but don't know how!
Re: Storage ideas?
Posted: Thu Jan 12, 2012 10:40 am
by Bamby
Mrtoler wrote:On page 38 of general toon discussion texaspontoon had some good ideas on this subject, I'd post the link but don't know how!
This is "How to post a link" click on URL button above, you will then see this open in the posing section then copy your link. Place your curser in the middle between ]l[ like this and paste your link and you should be good to go. You can check your link by previewing post if you care to to see if you've got it "right".
By the way is this the post you were referring to viewtopic.php?f=2&t=6438.
Re: Storage ideas?
Posted: Thu Jan 12, 2012 11:42 am
by GregF
If you like white buckets, check out the ones chlorine tabs come in (swimming pool).
They use a screw on lid. That is better than the snap on lid. There is a tall one, about the size of a drywall mud bucket and a shorter one that probably fits under most seats.
Re: Storage ideas?
Posted: Thu Jan 12, 2012 3:30 pm
by GregF
Saw an interesting idea today on a Benny.
The guy had a piece of 4" PVC mounted vertical on the corner of the rail (outside the fence) and he drops the stem of his anchors in them. One front and one back.
There was a milk box on the deck with the rode in it.
Re: Storage ideas?
Posted: Fri Jan 13, 2012 7:01 am
by kryptonite
For the ropes...
I use those cheap electric cord plastic wrap deals. Works good for all the ski ropes ect....
The reeled one is for the anchor rope....
Re: Storage ideas?
Posted: Fri Jan 13, 2012 9:07 am
by Leisure Kraft
Overton's appears to have an organizer, probably for under-seat storage.
http://www.overtons.com/modperl/product ... rchID=4006
I personally have some of those nifty mesh bags from the camping world that also work well.
http://www.backcountryedge.com/equinox- ... -x-16.aspx
Re: Storage ideas?
Posted: Fri Jan 13, 2012 10:57 am
by captainjack
Leisure Kraft wrote:Overton's appears to have an organizer, probably for under-seat storage.
those bags look like a good deal but they're discontinued
:donno
