Minn Kota with iPilot
NH Tooner
#1 Post by NH Tooner » Sun Jul 15, 2012 7:19 am
I have a 28' tritoon with 225 hp. I just tried out my Minn Kota trolling motor. The iPilot feature is AMAZING. I plotted a short course on the shoreline, (1000'). Hit return and it brought me back over the same course flawlessly. Back and fourth about 3 times. Had about 6-8 mph winds maybe more. Compensated for that with no problem. I also tried out the anchor feature. We stopped at a sandbar with lots of boats there. I hit anchor and it kept the boat at that same spot for over an hour. The boat never semed to move. Crouded with boats all around. Again with a slight wind worked flawlessly. Even with the two tops up catching the wind.
I highly recommend it.
Dave
2012 Homebuilt 28' Tritoon
225 hp Mercury
1993 24' Forester
50 hp mercury
blackberg
Re: Minn Kota with iPilot
#2 Post by blackberg » Sun Jul 15, 2012 10:45 am
def on my wish list,
what # thrust is yours?
-bb
Ron Burgundy
#3 Post by Ron Burgundy » Sun Jul 15, 2012 11:47 am
Yep, on the wish list. It will probably stay there because of the price, but it sure would be nice.
GregF
#4 Post by GregF » Sun Jul 15, 2012 12:28 pm
My neighbor has that on his trolling motor but be sure you have an extra battery. The thing is a battery hog if you are dealing with a lot of wind and current.
1974 Harris
70 HP 4 stroke EFI Yamaha
NH Tooner
#5 Post by NH Tooner » Sun Jul 15, 2012 6:47 pm
blackberg wrote:def on my wish list,
-bb
82# 24 volt.
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
NH Tooner
#6 Post by NH Tooner » Sun Jul 15, 2012 6:49 pm
GregF wrote:My neighbor has that on his trolling motor but be sure you have an extra battery. The thing is a battery hog if you are dealing with a lot of wind and current.
All depends on how you use it. I have the same t-motor on my other boat for the last couple years. never ever had battery issues.. That one is a 55# 12 volt. Any t-motor is a battery hog in wind or current.
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
megawatt
#7 Post by megawatt » Mon Jul 16, 2012 6:05 am
I bought a MinnKota PowerDrive (24V, 70 lbs thrust, 54" shaft) with iPilot about a month ago. This thing is amazing!
I was concerned about the thrust for my toon, but it's done great in 15 mph winds (the anchor function held the spot fine, and it pulls me along at almost 3 mph at full power).
I added a third battery so I don't have to mess with my cranking battery. I also bought the mounting kit, which leaves only a 4" x 6" pad when the motor is removed.
Richland-Chambers Reservoir, North Texas
2005 Harris FloteBote SuperSunliner 23' Tri-toon
Honda BF150
MinnKota PowerDrive V2 trolling motor w/i-Pilot
rancherlee
#8 Post by rancherlee » Mon Jul 16, 2012 6:51 am
Works great, tried one out. Also made Minnkota V1's pop up like crazy on craigslist for reasonable prices (only v2's are compatable). I pick up a gently used PD55 V! with copilot, autopilot, and sonar for 350$ because the owner upgraded to a 1100$ ipilot (and gave me a demo of the ipilot). Side note, you want AT LEAST a 55# for a 20ft pontoon. After playing with mine all weekend I found mine OK, but I needed to crank it all the way to 10 sometimes to control the pontoon in a 15mph wind. Pulls my boat along at 2-2.2mph @ 10
