Clear Plastic Windows Care and Maintenance
bug73
#1 Post by bug73 » Thu Jan 15, 2009 6:25 pm
From North American Waterway and Ostler Boat Tops.
http://www.north-american-waterway.com
Nothing makes a boat look more unkempt than cloudy, yellowish brown plastic windows.
If proper care isn't taken, the vinyl will become brittle due to loss of chemicals called "plasticizor". The plasticizors work their way to the surface over time, evaporating and leaving the vinyl brittle, cracked and cloudy.
Start the cleaning process by first rinsing glass with clear water to remove any dust or dirt particles. This should be done on a frequent basis to keep salt water and environmental agents off of your glass product. Using a soft non-abrasive cloth, wash curtains inside and out with a mild soap and water mixture. Rinse completely with cool water. DO NOT USE DETERGENTS! Polish glass inside and out with a manufacturer recommended product. DO NOT use chemicals on the vinyl glass. This will break down the protectors in the vinyl. You can remove some scratches from your glass by using a manufacturer’s recommended product. Do not fold clear vinyl glass, store flat or roll up.
- William Arthur Ward
25 foot Catalina Sailboat
agsbill
Re: Clear Plastic Windows Care and Maintenance
#2 Post by agsbill » Thu Jan 15, 2009 9:26 pm
I have read on other boat forums that you should NOT use Windex on plastic windows...
Bill
2004 Bennington 2575 RFS TRI-Toon W/Honda 225
native of Augusta, Ga...AGS (the airport code)
Vung Tau, RVN.. Mar 69-70
Home is..Gainesville, Ga. Lake Lanier
On a dry cove...Lake is down over 19'..now16' :)..
bug73
#3 Post by bug73 » Sat Jan 17, 2009 3:44 pm
I dont have plastic windows yet, but I wouldnt after reading the above. It sounds like what armor all does to tires, it removes the natural lubricants and protectants from the product you put it on.
#4 Post by badmoonrising » Sun Jan 18, 2009 2:46 am
A few years back I had a canvas top on my Ford Ranger made by Safari Tops in VA (no longer in business). The owner of the company told me to use Pledge furniture polish without lemon in it.
Don't know if that's still true these days though.
