A tip if you're laying vinyl or carpet
sunedog
#1 Post by sunedog » Mon Mar 25, 2013 7:39 pm
My carpet was worn out so I'm replacing it with vinyl from pontoonstuff.com. (They are fantastic to work with. Just like everyone on here says. I can't say enough good things about them.)
The sales manager at my local Bennington dealer (Chase at Captain's Choice Marine in Leesville, SC) gave me a time and aggravation saving tip: Instead of disconnecting all wiring, motor controls and steering cables to completely remove the console, loosen everything up a bit and lay the console over on it's side next to the deck of the boat. When you lay the vinyl or carpet, cut a slit from the side into the hole in the deck that all the wires and cables come through. When you have it all put back together, the trim covers everything (or all but about .25") It is not noticeable.
My Herby Curby trash bin was the perfect height to rest the console on.
In my case, I had to cut all the tie wraps for the power steering cable back near the motor and provide some slack to the console. I also cut all the tie wraps around the 100's of wires and disconnected a large wiring harness connector to create some slack under the console. But I did not have to disconnect the power steering cables (which likely would have created a huge mess) or the motor controls.
Here's a shot of me spreading vinyl for the second half.
And here's my bride rolling with the 75 lb roller. I agree with herb -- Do not skip the roller rental. It was borderline too cold for this job (around 60 degrees) so we used a lot of masking tape to hold the edges down. Thanks for the tip on the tape, ToonGuy.
Re: A tip if you're laying vinyl or carpet
#2 Post by lakerunner » Mon Mar 25, 2013 7:48 pm
Great post
chill'nthemost
#3 Post by chill'nthemost » Mon Mar 25, 2013 8:23 pm
For sure :thumbsup
#4 Post by HandymanHerb » Tue Mar 26, 2013 12:09 am
Good job :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup
Texoma Toon
#5 Post by Texoma Toon » Tue Mar 26, 2013 3:04 am
HandymanHerb wrote:Good job :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup
Ditto :thumbsup :thumbsup
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
cleatus
#6 Post by cleatus » Tue Mar 26, 2013 5:05 am
well done!
you're gonna love the vinyl, so easy to clean the fish goo, spilt beer/soda pop etc., just splash a bucket of water on it.
be sure to add spacers under the fence rail on the re-install.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
redbeard
#7 Post by redbeard » Tue Mar 26, 2013 6:11 am
Great job , keep the :pics comeing. :thumbsup :thumbsup :thumbsup
#8 Post by Bamaman » Tue Mar 26, 2013 6:41 am
Even if you're installing new carpet, the roller is very important to use. They rent for about $20 per day, but they will certainly minimize any bubbles in the carpet.
Another suggestion is to use the proper mastic to install the flooring--whether it's vinyl or carpets. Just because a mastic is available at Home Depot or Lowes doesn't mean it's the right glue to use for the purpose. You need to carefully research what kind of glue to use, as there are a dozen different kinds for different applications.
sunedog
#9 Post by sunedog » Tue Mar 26, 2013 9:51 am
Bamaman wrote:Even if you're installing new carpet, the roller is very important to use. They rent for about $20 per day, but they will certainly minimize any bubbles in the carpet.
This roller cost $15 for 24 hours. And the mastic came from pontoonstuff.com because I bought the vinyl flooring kit. I let them figure out what to use since they sell it all the time. And this 2000 Bennington had rail spacers from the factory. Just re-used tem.
evinrude2stroke
#10 Post by evinrude2stroke » Tue Mar 26, 2013 2:29 pm
Nice tip..Cant wait to see the finished pics. I would love to convert mine from carpet to vinyl someday. :thumbsup :thumbsup
Dave
bassn386
#11 Post by bassn386 » Tue Mar 26, 2013 2:35 pm
A few more pics and you'd almost have a complete DIY portfolio.
Nice job from someone who wouldn't even think of tackling a job like this.
But, I make a hell of a quality control supervisor!
F225 Yamaha
