trailers
tim22
trailers
#1 Post by tim22 » Sun Mar 08, 2009 5:04 am
I bought a 22 Bennington and need some info on the best trailer to get. This boat will have to travel on a highway for over 300 miles. Any tips- pointers - hints and experinces (good or bad) that would help me out.
TIM22
Re: trailers
#2 Post by lakerunner » Sun Mar 08, 2009 7:35 am
Lots of good trailers out there as there are some junk. Look at Gauge of steel used as some is paper thin. On your axles I would look for the kind with grease cert in center pushing grease from rear to front. They should have a small rubber plug on bearing cover.
Most don't but I prefer 10" wheels for a lower profile. If you go that way get 10 ply tires. I hate surge brakes but about all you can get.
Don't forget a spare tire and carry a jack and lug wrench that fits
Make sure they have good upright guides as most are flimsy junk.
Get LED lights for less problems.
Welcome and good luck
crankshop1000
Re: trailers
#3 Post by crankshop1000 » Tue Apr 14, 2009 7:05 am
Get a bunk type rather than a crankup style. I have seen 2 tipped over toons hauled on the crankup trailers. The wheels ar too close together for stability in turns.
jafo9
Re: trailers
#4 Post by jafo9 » Tue Apr 14, 2009 1:22 pm
bearings aren't that expensive and neither is a bearing packer. before i go on a long trip with my any of my trailers (no pontoon trailer) the bearings get a good check up. especially the axles that get wet. most trailers weren't designed/rated to go the speeds we pull them at so i figure the bearings/axles/tires have less tolerance for heat/error/dirt.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
beermunk
Re: trailers
#5 Post by beermunk » Wed Apr 15, 2009 5:25 pm
Trailering Rules:
- Inflate tires to max cold PSI exactly
- Inspect bearings twice a year if you dunk the trailer often
- Properly load your tow vehicle
- Never exceed 60mph towing
- If trailer is equipped with surge brakes, check fluid every trip
That's everything I can think of at this point. Oh BTW
_________________________
Buy the ticket - Take the ride.
- H.S.T.
Re: trailers
#6 Post by HandymanHerb » Wed Apr 15, 2009 5:39 pm
I like the roller trailers rather than bunks, my toons dry compleatly , easier to get clean as you don't have to jack them off the bunks and no carpet to replace.
exospex
Re: trailers
#7 Post by exospex » Thu Apr 16, 2009 6:15 am
I bought a Karavan bunk trailer. It's a good heavy Galvanized dual axle trailer. It's nice. I bought it brand new for about $2800. It doesn't have brakes as it is really just used for dry winter storage. Oh, and the ladder up the front is a must. As Herb said, a roller trailer would have been much better, but they weren't available quick enough for me.
Matt & Kerrie
----2004 Aqua Patio 240RE----Cross Lake-Western NY
Onion Creek Farms----Rubs, sauces and spices----"Eat well, laugh, and enjoy life"
Drago
Re: trailers
#8 Post by Drago » Thu Apr 16, 2009 8:39 pm
I've had our EZLoader TEZP 24-26/28 for just slightly over 14 months. I've gotten fairly fond of it even though I have never trailered anything before our 25 ft. Bennington (seems like such a big load to pull around). It has Surge brakes, Reliable wet oil bearings, LED lighting, a good strong ladder up front and 4 Marathon ST185\80R 13c tires rated at 1480 lbs @ 50 psi cold. Those 4 Goodyears are from New Zealand and the spare Marathon is made in China (go figure). I've never felt like the tires were totally adequate but was told by the dealer, whom I trust, that they are completely good tires. He did recommend to get two spares - he drives at 70 or above pulling new customer boats all the time! Did I mention that it is galvanized also. It seems to be a well made trailer. The only thing I might consider adding is some sort of transom saver (Rinker says it's totally unneeded) and some glide slykes to the bunks.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
