Toon lift
waldosmith
Toon lift
#1 Post by waldosmith » Tue Mar 24, 2009 6:32 am
I want to lift my toon inside my boathouse with 4 manual hoists with straps going under the toons goint the beam of the boat and then putting 4 by 4's under the toons? For a week at a time. Whatcha think?
jimrs
Re: Toon lift
#2 Post by jimrs » Tue Mar 24, 2009 7:19 am
HUH??????????????????
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
cwag911
Re: Toon lift
#3 Post by cwag911 » Tue Mar 24, 2009 7:26 am
I agree. HUH ?????????
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
Re: Toon lift
#4 Post by badmoonrising » Tue Mar 24, 2009 9:00 am
Welcome ! also, huh x3.... :tofunny
Re: Toon lift
#5 Post by HandymanHerb » Tue Mar 24, 2009 9:56 am
Welcome and draw us a picture of what your trying to do, the straps I understand are you saying you want to mount the 4x4's to the strap for the toon to sit on?
OldePharte
Re: Toon lift
#6 Post by OldePharte » Tue Mar 24, 2009 1:08 pm
You didn't mention if you have a floating dock or not.
One concern that I would have is that running straps under the tubes is going to place a huge side load that they may not be designed to handle. You'll be squeezing them inwards, regardless of the 4x4's.
Another concern is having 4 manual hoists. You would need 4 people to raise/lower the boat at all times.
You may be better served looking for a way to raise/lower a lift that the boat sits on.
Assuming your boat house is on piles, one could look at some thing like this - http://www.hewitt-roll-a-dock.com/lifts07/pontoon.html There are other similar types out there.
FloterBoter
Re: Toon lift
#7 Post by FloterBoter » Wed Mar 25, 2009 3:04 am
depending on how long your boat is, you should consider more than two contact points on each toon.
either run bunks along the toons and lift them, or build a frame with 3 or 4 crossmembers that all
touch the toons. also, i wouldn't mess with 4 winches. i would layout some cable pulleys to come
up with a combined single pull that i would drive with one electric winch.
if you're going to lift the toon, you really need to keep an eye out for leaky toons. if you get a lot
of water in a toon, you might break your lift. it's more common than a lot of people think.
fb
