Anodes on pontoons
martys
Anodes on pontoons
#1 Post by martys » Sun Apr 19, 2009 5:21 pm
I'm close to buying my first pontoon, a Manitou Oasis SHP with a 200 E-TEC motor. I asked the sales rep about zincs or anodes on the toons because the boat will be kept in the water all summer (Middle River, in the Chesapeake Bay) and he told me the zinc package can cause more problems than it prevents. I like to hear some other opinions. :hammer
Premier 22.5 Legend Triple
150 E-Tec
Baltimore, Maryland
Re: Anodes on pontoons
#2 Post by HandymanHerb » Sun Apr 19, 2009 6:58 pm
I can't help you but I can say Welcome, you think the engine would come with one on it to protect the engine, I don't leave mine in any water for more than 3 days at a time so far and only in fresh water so I let Ed jump in on that one as he in that area.
#3 Post by badmoonrising » Mon Apr 20, 2009 5:14 am
I have a slip in the Bohemia River, in the Upper Chesapeake bay and in 3 seasons the factory anodes on the motor have done the job. It is HIGHLY advisable that you have the bottom painted. We get barnacles up this way and since you are a bit further south you will too. Along with red and green algea...
My Tracker dealer actually told me to maintain the hull warranty, I had to have the bottom painted.
Prior to launching last week, I replaced all the drive anodes as 2 were about 40 percent degraded. Complete package was $50 and well worth it.
Btw, welcome ! I'm fishing in the middle bay out of Matapeake all summer aboard my Starcraft. I fish around the bridge pilings and around the gum thickets, rock piles and Love Point.
mike
Site Owner
#4 Post by mike » Mon Apr 20, 2009 10:20 am
Welcome!! I was always under the impression that sacrificial anodes were more for salt water use??
martys
#5 Post by martys » Mon Apr 20, 2009 12:07 pm
For my understanding, there are no zincs or anodes on any of the three pontoons, just bottom paint. The only zincs are on the motor itself.
150 E-Tec
Baltimore, Maryland
WaltF
#6 Post by WaltF » Mon Apr 20, 2009 1:02 pm
Mike... Nope... :)
I have em on mine and after just 1 summer in the fresh water slip, you can see them 'working'... :)
I have the same motor as BMR. There is something like 6 of em on the drive unit...
http://www.defender.com/html/zincs_info.html
Colorado Springs, CO.
#7 Post by badmoonrising » Mon Apr 20, 2009 1:56 pm
Middle River's salt content is enough to cause hull corrosion, it's a river off of the bay's mainstem. Spring, it's relatively fresh and as the summer goes on a little saltier, especially during droughts.
#8 Post by badmoonrising » Mon Apr 20, 2009 2:00 pm
mike wrote:Welcome!! I was always under the impression that sacrificial anodes were more for salt water use??
More of issue in saltwater, but no. There are actually anodes made for fresh and saltwater. You can get quite a bit of hull pitting/electrolysis in freshwater lakes just the same as where I am. The fact that Walt's are working (degrading) proves that.
There's also anodes in most home hot water heaters. If you've ever changed one, eeeewwww.... :tofunny
#9 Post by badmoonrising » Mon Apr 20, 2009 2:02 pm
martys wrote:For my understanding, there are no zincs or anodes on any of the three pontoons, just bottom paint. The only zincs are on the motor itself.
That's all you'll need. Keep an eye on all of them, replace as needed and you'll be fine.
mike
Site Owner
#10 Post by mike » Mon Apr 20, 2009 2:45 pm
good info guys, I learned something today! :guitar My toon never sits in the water long enough to sacrifice its anodes! :donno
martys
#11 Post by martys » Mon Apr 20, 2009 4:02 pm
I just figured that each toon would have some type of anode on it along with bottom paint. For any new boater in my area, if you are going to leave your boat in the water all summer, YOU MUST have a good bottom paint on the hull with zincs on the motor. I change the zincs on my MerCruiser every other year.
150 E-Tec
Baltimore, Maryland
kimbercarry
#12 Post by kimbercarry » Tue Apr 21, 2009 8:33 am
I keep the yammy 150 in the raised position per my dealer so the anodes are not in the water. There are metal hull boats with shore power all around me should I install anodes on the logs as well?
#13 Post by badmoonrising » Tue Apr 21, 2009 8:47 am
Well if your motor is raised out of the water, the anodes aren't protecting your engine or the hull from corrosion. IMO, lower the drive and don't waste your time adding hull anodes. BUT if you must do so it certainly won't hurt, it's just adding to maintenance costs at no real benefit.
