3 bank charger?
3 bank charger?
Looking to get a new pontoon and need a 3 bank charger (3 batteries/24 volts). XPS series at BassPRO xps it 5/5/5 for about $150. Any advice for or agin? Thanks in advance.
Re: 3 bank charger?
No experience with the Bass Pro one, but these are pretty decent:
http://www.cabelas.com/product/Cabelas- ... Collection
As with everything from Cabelas, they go on sale periodically so if you don't need it right away you can wait a while to get it 20-30% cheaper.
I've only used our 5/5/5 Cabelas charger but it works well and charges AGM or flooded cell batteries.
- killerkernrich
Re: 3 bank charger?
I have a 24v set up but only 2 batts with a 2 banks of 5 each, they are minn kotas
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
Re: 3 bank charger?
The 3bank is convenient as you can top-off your starter battery as well. I too have a 24V setup. (2) deep cycle batteries and (1) starting battery. The third bank is convenient if you don't run your main motor enough to fully charge your starter battery or if you want to top off the batteries after sitting for a while.killerkernrich wrote:I have a 24v set up but only 2 batts with a 2 banks of 5 each, they are minn kotas
Re: 3 bank charger?
I have a minn kota 3 bank charger and it works good but unfortunately its over 300 bucks.
