riding low
silverfarm
riding low
#1 Post by silverfarm » Mon May 11, 2009 6:49 am
My boat seems to be fairly low in the water and it seems to have a hard time cutting. Does this mean I have water in the logs or is this fairly rare?
1997 Fisher 200DLX
2004 Merc 60hp 4stroke
mike
Site Owner
Re: riding low
#2 Post by mike » Mon May 11, 2009 6:56 am
What are the specs on your toon? How long, how many logs, what size logs, how much weight do you have loaded?
silverfarm
Re: riding low
#3 Post by silverfarm » Mon May 11, 2009 7:14 am
20' Fisher 200dlx. 60hp merc 4stroke. Not sure of the log size...standard.
1997 Fisher 200DLX
Re: riding low
#4 Post by HandymanHerb » Mon May 11, 2009 7:49 am
Is it riding low all around, back or one side
silverfarm
Re: riding low
#5 Post by silverfarm » Mon May 11, 2009 8:24 am
I posted earlier under “log spray issues” and am trying to diagnose performance problems. Recently went from a 40hp Tracker to a 60 4strk Merc thinking it would get me up on top of the water a bit better. While it does move faster, at full throttle, water comes off the interior spray fins hitting the floor and up through the carpet. It is riding a bit lower in the back (due to the larger engine) but doesn’t seem a lot lower overall when looking at the previous water lines on the tubes. Is the spray issue due to the larger motor and could I just bend the fins down to solve the problem or do I have a bigger issue? Thanks much!
1997 Fisher 200DLX
Re: riding low
#6 Post by HandymanHerb » Mon May 11, 2009 8:42 am
We need pictures of it sitting in the water, if your plowing or pushing water with front toon you have to much weight up front, under skinning will take care of the splash coming through the carpet, we all get water splash from the toons.
Re: riding low
#7 Post by dockholiday » Mon May 11, 2009 8:46 am
If you have a trailer, do the slosh test. Back the boat and jump on the brakes, if you have water in there, you will hear it. Helps to have someone walk along the side while doing this, even a small amount of water can be heard. Don't think I would try and bend the fins. Positioning most of the weight near the rear should help some on the plowing.
Re: riding low
#8 Post by lakerunner » Mon May 11, 2009 4:51 pm
I think most of your spray problem is from bigger engine. With the 40 you just plowed along not pushing much water out. Now you have more power and more speed so more spray and being thrown farther. Bending fins won't help much and might crack if you try.
FloterBoter
Re: riding low
#9 Post by FloterBoter » Mon May 11, 2009 9:29 pm
two words: TAP FINS
:tofunny
but seriously folks...
like herb said, you need to post pics.
WaltF
Re: riding low
#10 Post by WaltF » Tue May 12, 2009 8:29 am
gonna have to wash your dern mouth out with soap Floter! :nutkick
Colorado Springs, CO.
beermunk
Re: riding low
#11 Post by beermunk » Tue May 12, 2009 5:51 pm
Remember that if your fuel tank is on one side of the boat, it'll lean that way in the water when it's full.
_________________________
Buy the ticket - Take the ride.
- H.S.T.
Re: riding low
#12 Post by badmoonrising » Wed May 13, 2009 7:07 am
Don't Tap Fins make the problem worse ? All those holes from sheetmetal screws cause leaks.... :tofunny
