Just another prop question
vlxerdon
#1 Post by vlxerdon » Mon Sep 21, 2015 8:00 am
Need a bit of help from some of the prop smart folks here. What I have is in my sig. I run two different props depending on my location and load.
A 14 x 13 and a 14 x 11 three blade aluminum. Both props keep me where I should be as far as R.P.M.' go. Between 4500 and 5500 on my engine.
My problem, I am 800 miles away from my boat for the next couple of weeks.
At a flea market here I picked up a new in the box three blade S.S. prop for real cheap. The size is 13 3/4 x 13. My question is what kind of difference can I expect as far as R. P. M. 's go. If it will not work for my boat,I'm sure I can get my money back in a resale, just could not pass up a bargain. :)
I appreciate any and all help. Thanks in advance.
JD
1994 Starcraft Stardeck 200
1998 Johnson 90HP
98 5.9 V8 Magnum Dodge Ram
Re: Just another prop question
#2 Post by RcgTexas » Mon Sep 21, 2015 12:08 pm
Your just purchased prop(13 3/4 x 13) will let the engine turn up more than the 14x13 not much, but a little more , you may not even notice the difference on your tack. Maybe only a couple of hundred revs if that.
I'm guessing your 14 x 11 should let your engine run close to the top rpm. I'm guessing there is a big difference in the rpms of your two original props.
vlxerdon
#3 Post by vlxerdon » Mon Sep 21, 2015 12:31 pm
RcgTexas wrote:Your just purchased prop(13 3/4 x 13) will let the engine turn up more than the 14x13 not much, but a little more , you may not even notice the difference on your tack. Maybe only a couple of hundred revs if that.
Thanks. Searching the net does not give hardly any info on rpm change with diameter,just pitch. You are correct in the rpm difference in my props 5000 with the 13 and 5500 with the 11 pitch
The 13 seems to be ok if the wife and I are putting in at the river just for some fun on the water.
When we are going shrimping,crabbing or fishing in the sound I run the 11 cause we are usually loaded with all kind of goodies. :)
Great to know there will not be much change using the new prop. Paid $50.00 for it. Crazy cheap. Thanks again for your help.
JD
1998 Johnson 90HP
DWRAT
#4 Post by DWRAT » Mon Sep 21, 2015 4:24 pm
Your RPM's may be about 50 lower and your top speed should be up a couple MPH.
I personally got 4 MPH with a SS prop.
vlxerdon
#5 Post by vlxerdon » Mon Sep 21, 2015 6:47 pm
DWRAT wrote:Your RPM's may be about 50 lower and your top speed should be up a couple MPH.
Many thanks. Appreciate it.
JD
1998 Johnson 90HP
