Power Bimini tops
vlxerdon
Power Bimini tops
#1 Post by vlxerdon » Fri Oct 02, 2015 2:33 pm
Anyone have the power top that Pontoonstuff has on sale ?
Sure looks good to these old eyes. Gettin harder and harder to raise mine by myself anymore. That's with no wind even. :)
Would really like to get some real world input before I pull the trigger on one. Retired on a fixed income tends to make one a bit cautious before spending money.
Appreciate any and all input. Thanks in advance.
JD
1994 Starcraft Stardeck 200
1998 Johnson 90HP
98 5.9 V8 Magnum Dodge Ram
Re: Power Bimini tops
#2 Post by Bryden24shp » Fri Oct 02, 2015 2:39 pm
No, I do not.
#3 Post by Bryden24shp » Fri Oct 02, 2015 2:40 pm
Sorry, couldn't help myself..... :biggrin2
Gonefishing
#4 Post by Gonefishing » Fri Oct 02, 2015 3:56 pm
I have one and have had over a year now. Installed it my self without a problem. It is great just need to make sure you put it where you want the most shade. What I like about it is you can have it provide more or less shade in the front or rear. Just depending when you and the family is sitting at the time or how the sun is shining
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
garygve
#5 Post by garygve » Fri Oct 02, 2015 5:43 pm
I installed one a month ago works great haven't wired up the wireless remote yet, probably do that this winter.
If you want to save another $80.00 type forum10 in the discount code box at checkout.
150 Mercury 4-stroke
vlxerdon
#6 Post by vlxerdon » Fri Oct 02, 2015 6:46 pm
Bryden24shp wrote:Sorry, couldn't help myself..... :biggrin2
It's OK. I know what it's like to have that type of sense of humor. A lot of people would not think it was funny, but I did. :nana
JD
1998 Johnson 90HP
vlxerdon
#7 Post by vlxerdon » Fri Oct 02, 2015 6:50 pm
Thanks gentleman. Great info so far. I am really wanting one.
The video on the top shows it as being pretty sturdy in the " Radar bridge " position. Have either of you run in that position and is it stable.
JD
1998 Johnson 90HP
Gonefishing
#8 Post by Gonefishing » Sat Oct 03, 2015 7:57 am
I have run mine all the way down, all the way up open and all the way up fully closed mid way up I think about in any position I could put it in and have had no problems with. It is a very sturdy top. Only issue I have had is with the remote sometimes it will not work and that may be because of where I have the box for it. But not a big deal since I use the toggle switch and haven't had much of a need to lowere and raise it when not on the boat
2013 115 Yamaha
vlxerdon
#9 Post by vlxerdon » Sat Oct 03, 2015 11:02 am
Gonefishing wrote:I have run mine all the way down, all the way up open and all the way up fully closed mid way up I think about in any position I could put it in and have had no problems with. It is a very sturdy top. Only issue I have had is with the remote sometimes it will not work and that may be because of where I have the box for it. But not a big deal since I use the toggle switch and haven't had much of a need to lowere and raise it when not on the boat
Once again, thank you for the info and all the help you have been. That top is on my to get A.S.A.P. list. Apreciate it.
JD
1998 Johnson 90HP
Drago
#10 Post by Drago » Fri Oct 09, 2015 5:43 am
I'm 63 and have a hard time getting mine up too :( What I've found really useful is a docking hook.
http://www.westmarine.com/hooks
I get under mine and use my legs to raise it pushing up with the hook. I can then reach over and move one of the supports to lock position. I then extend the hook to pull the front cross bar to the front, unfurling the bimini. I normally do not keep mine all the way down to the highway position as I see you do for storage.
A hook is a worthwhile investment so getting one and trying it would cost little.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
vlxerdon
#11 Post by vlxerdon » Fri Oct 09, 2015 6:32 pm
Drago wrote:I'm 63 and have a hard time getting mine up too :( What I've found really useful is a docking hook.
I'm 69 and I have a hard time getting mine up also......Oh wait..... You meant the top....Silly me. :nono
Thanks for the great idea. Yep, keep mine in the down position for storage and going to and from the ramp and it is getting to be a bear anymore.
JD
1998 Johnson 90HP
NH Tooner
#12 Post by NH Tooner » Sun Oct 18, 2015 6:31 am
I have 2 on my boat. Installed them back in 2012. I like them a lot. never hooked up the remotes as I had no need for them.
google pwr arm bimini top and you will see a short video of my boat when I installed them. The canvas is kind of thin material. The bows are far apart and the top will pond water if you leave them up in the rain. I ordered a couple more bows to install between the existing ones but never did that either. All in all I like the tops, they work great and recommend them.
Dave
2012 Homebuilt 28' Tritoon
225 hp Mercury
1993 24' Forester
50 hp mercury
vlxerdon
#13 Post by vlxerdon » Fri Oct 23, 2015 12:27 pm
NH Tooner wrote:I have 2 on my boat. Installed them back in 2012. I like them a lot. never hooked up the remotes as I had no need for them.
Thanks. Good to know about the pooling water stuff. I trailer so the only time the top is up is when the wife and I are on the boat.
JD
1998 Johnson 90HP
