water in gear box
Posted: Wed Oct 21, 2015 7:37 am
by lakerunner
Well drained lower unit and had water in it. Going to pull and take to mechanic for seal test.
Re: water in gear box
Posted: Wed Oct 21, 2015 8:07 am
by RcgTexas
Good idea but...................I would just change them all! regardless. While you have it down it may be the best thing to do.
Posted: Wed Oct 21, 2015 8:21 am
Vacuum & pressure test is something few do often enough.
I ignored my lower unit, and it turned to toast (Yamaha 115 hp 2 stroke.) Spent 4th of July watching everyone on the lake drive by our house.
We had to buy a whole new boat.
Posted: Thu Oct 22, 2015 8:24 am
by lakerunner
He is going to make sure bearings are good and go ahead and replace all seals. Also install new impeller while out.
Posted: Thu Oct 22, 2015 8:41 am
by HandymanHerb
Posted: Thu Oct 22, 2015 9:32 am
by BobG
Yeah, I replaced my impeller for the first time... And I had water when I drained it.
The instructions I followed did NOT mention sealing the lower unit when I put it back on. It's sealed now!
Posted: Thu Oct 22, 2015 12:49 pm
by curtiscapk
Glad you csught it Lloyd. Matter of fact I need to make a post about the only useful tip that I actually use of yours ever since I joined 7 years ago.
Luckily mine was nice and black and stinky last weekend.
Posted: Thu Oct 22, 2015 1:41 pm
by RcgTexas
Another great idea.
A good mechanic told me a few years ago that a lower unit take down and impeller change every two years is a good Idea. for the impeller as well as the lower unit bolts being taken out and cleaned so as to prevent seizure which id very expensive when it happens. I can see the logic in that as well.
Posted: Thu Oct 22, 2015 1:53 pm
by lakerunner
Well he called a bit ago and said he pressure tested and all seals held pressure for 2 hours. He told me my driveshaft seal almost looked melted on top flange. He ask how I use boat because he has seen other evinrudes that spend a lot of time at idle getting the driveshaft seal under the impeller get hot. Well I spend 90% trolling at 900 rpm. He said to just replace driveshaft and gear shaft seals as the propshaft seal was fine.
What tip was that Craig?
Posted: Fri Oct 23, 2015 8:15 am
by curtiscapk
Posted: Fri Oct 23, 2015 9:51 am
by lakerunner
I had forgot that.
More BBQ this weekend. Look for pics
