Double TOPS
LittleRiver
Double TOPS
#1 Post by LittleRiver » Thu Oct 29, 2015 12:49 am
Called tracker they said they did not offer a double top in my year boat any more. Who needs them anyway. :prayer :happy
Took the measurements, did a little Carolina Figuring,, :thumbsup ,, got on the phone with a couple of companies, found square tubing that had adjustable tubes. HOT DOG. That was all I needed. Go over lapped. :thumbsup
You know how you start something then it just ain't quite as perfect as you want it . :lol:
Got the front top on, back top color didn't quite match, you know the rest of that story. Have right in a grand in ordering the front and having the back top built new.
Shop screwed their first try right bad, had to end up taking them the pontoon finially got it back last week. Ya I know, its cold weather now. Sounds like a remake of doing all the custom work to it last year then it turned cold. :(
Shes ready for next year though. Fun, sun, some sun, just depends on how the mode strikes me.
If any of you are interested, just get tubes that adjust. You can move the top up or down, drop one side or bring one side up so it fits perfect over lapping the other top about 5 inches.
Wish they still offered the two tops that connect, but I bet I would not of got it for $550 shipped.. :thumbsup
Tucked away ready for winter. Didn't have time to drop the tops last week, throw on the cover, can't wait till spring. :)
[i][color=#0000BF] ...08 24' Party Barge "Tiggers Toy" 50hp..[/color][/i]
[i][color=#0000BF] ..Triton TR21X 250 V-Max "Yellow Bullet".. [/color][/i]
[i][color=#0000BF] .. Little River Motorsports Top Dragster T/D[/color][/i]
[i][color=#0000BF] ..Dodge and Ford truck, but still race a Chevy[/color][/i]
Cowracer
Re: Double TOPS
#2 Post by Cowracer » Thu Oct 29, 2015 5:58 am
I did the same thing. Best money I have spent on the boat. I had to get a bit creative because my rear legs of the front top would have set down right on the side gate. This was my solution:
It's unreal how much more comfortable the boat is with the second top.
Tim
smltooner
Re: Double TOPS
#3 Post by smltooner » Thu Oct 29, 2015 5:22 pm
Both look like great ideas.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
LittleRiver
Re: Double TOPS
#4 Post by LittleRiver » Thu Oct 29, 2015 5:55 pm
Cowracer wrote:I did the same thing. Best money I have spent on the boat. I had to get a bit creative because my rear legs of the front top would have set down right on the side gate. This was my solution:
Tim
Ya,, you can sun when you want, go undercover when you don't. Looked like the way to go..
Got lucky on mine. Had to drill a couple of holes where they won't any on the adjustments but other than that, she fit right on, and bolted right up. Getting someone to help hold it steady was about the hardest part.
Thanks for posting Cowracer. Glad to see i'm not alone. :thumbsup
PlaynDoc
Re: Double TOPS
#5 Post by PlaynDoc » Thu Oct 29, 2015 8:19 pm
mine is set up same way
Dragon1
Re: Double TOPS
#6 Post by Dragon1 » Thu Oct 29, 2015 8:32 pm
I am also planning to add the 2nd bimini. Great options above to elilminate the gate issue.
May I ask what bimini supplier you used ?
My other issue is to try to match /get close to the burgundy on my original bimini- yup ST 's supplier (Dowco) has discontinued that color. My orig bimini still vg condition.
Thanks
'08 SunTracker PB 24
Merc 60 BF EFI, Tracker Trlr
Lake Nacimiento, Ca.
LittleRiver
Re: Double TOPS
#7 Post by LittleRiver » Fri Oct 30, 2015 6:44 am
Dragon1 wrote:I am also planning to add the 2nd bimini. Great options above to elilminate the gate issue.
Thanks
I made a boo boo which led me to getting involved in both projects. I"m one mile from the boat ramp. Shed was for the Fountain offshore I sold so its high enough to leave the cover up. I usually run about 40 to 45 to the landing with the top on but passed a tractor mashed it and the guy I had bought the boat from had left the top up out in the sun for 5 years. You know what happened to the back top. :roll: :roll:
Ordered the front pacific blue then had the local tarp guy try and built one out of the old tarp. He said he could. Man did he make a mess out of that thing would not even fit. Had to take him the pontoon and let him start all over. Don't even do that. Take it to who ever is building your top, let them fit it to the rails.
Agree totally two different colors, or shades ain't going to look uniform but they sure will work.
ON the ordering, I hate to say it but don't have a clue. Found them on e bay, its 1.25" square tubing called them and ordered direct and yes they give you a discount. They had good feedback so felt I was ok. . Been about two months maybe a little more so you know where that box and the rest are. :happy
I would try and get the 1.25 square tubing. ITs a lot stronger and not sure adjustments come in round tubing and thats what I had on the back.
Once I seen it worked and everything was good, for what I spent on it , I can't complain so don't even worry about sending something back.
zoom650
Re: Double TOPS
#8 Post by zoom650 » Fri Oct 30, 2015 7:07 am
It's worth all the trouble to set up. Hard to beat a double bimini when the sun is bearing down!
Cowracer
Re: Double TOPS
#9 Post by Cowracer » Fri Oct 30, 2015 7:59 am
Thanks
I got mine from PontoonStuff.com. The front top is new. The rear is factory Bennington. The color of the new top is close enough as makes no difference, but it not quite as opaque. It lets in noticeably more light. Not really an issue. Installation was a breeze, provided you have a helper or two (two is better). The only two drawbacks to my setup is:
#1 that I HAVE to run both tops up, or both tops down. I can't run just one top up, because I need both for support. But that is not a big deal for me. It takes literally just seconds to deploy,
and #2 despite warning everyone else to watch their heads, I personally have brained myself on the cross bar twice now getting on or off the boat at the dock. D'Oh!
Tim
