stereo system
numbfingers
stereo system
#1 Post by numbfingers » Mon Feb 29, 2016 11:43 am
Hello all am looking for opinions on a decent stereo system, price range to about 250. Not wanting to rock the world just want a nice sound and dependability. thank you in advance Duane
1992 21ft suntracker party barge 90 hp Johnson
Comstocker
Re: stereo system
#2 Post by Comstocker » Mon Feb 29, 2016 3:06 pm
First thing you'll need to figure out is what you want to listen to; AM/FM, blue tooth phone, USB memory stick, aux port with an mp3 player, etc. Once you have that down, then you can decide what you need for the head unit to make sure it does what you want/expect.
Then look at speakers after that. Decent three way 6 1/2" round speakers mounted in the seat bases are usually the easiest. You can find good speakers for around $50-$75 per pair if you're not looking at high-end stuff. Typical set-up would have four speakers total, two front and two rear.
Don't forget an antenna and speaker wire that can handle the weather and moisture.
Ken McMillan
Mayor of 100' of Paradise on Comstock Lake
TDJ2591
Re: stereo system
#3 Post by TDJ2591 » Mon Feb 29, 2016 4:45 pm
Price was a controlling factor in my selection as was quality. Here's what I installed. I bought the 4 Speakers and Bluetooth receiver for under $250 as I recall. The sub-woofer and amp can be found for under $150 (installing sub this weekend). It sounds great even without a sub, has plenty of clean, clear volume, removable face plate, Bluetooth for music and phone and a real sensitive microphone for hands free communication. You can download the user manual and read about all the features. There may be newer models available.
Stereo: KMR-D558BT - Receiver
Kenwood KFC-1652MRW - 6.5" speakers
Kenwood P-WD250MRW - 10" Sub-woofer & amp
My only complaint: hard to read the dial in bright sunlight. This model does not accept a wireless remote but will accept a wired remote. Newer models may have a wireless remote.
numbfingers
Re: stereo system
#4 Post by numbfingers » Tue Mar 01, 2016 5:27 am
thank you all for the input. gonna delve into it a bit now .
HarryO
Re: stereo system
#5 Post by HarryO » Tue Mar 01, 2016 2:50 pm
Try Crutchfield for stereo components. I just purchased a Kenwood HD receiver with bluetooth, CD player, remote and USB for $89.00. There is very little difference between a car stereo and a marine stereo. As long as you install it where it won't get wet.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
sunedog
Re: stereo system
#6 Post by sunedog » Wed Mar 02, 2016 5:28 am
HarryO wrote:Try Crutchfield for stereo components. I just purchased a Kenwood HD receiver with bluetooth, CD player, remote and USB for $89.00. There is very little difference between a car stereo and a marine stereo. As long as you install it where it won't get wet.
I used to share that sentiment and had good luck for years with normal car stereos. Then I had two car stereos get wet and get ruined in consecutive seasons. Don't even know when they got wet. There were no spilling or rainstorm incidents. Maybe it was a humidity thing. So I went with a Kenwood marine stereo last year.
TDJ2591
Re: stereo system
#7 Post by TDJ2591 » Wed Mar 02, 2016 11:11 am
I replaced a marine Clarion receiver and 4 speakers with the Kenwood marine. I believe that humidity was a problem with the Clarion as it worked intermittently, plus one speaker had gone out. My son has it in his bowfishing boat and has occasional problems when it's really humid. Marine radios reportedly have internal coatings and typically tinned wiring to protect the components from moisture. Car radios lack that treatment.
By the way, if you don't already have a marine FM antenna on your boat, you will want to pick one up for your new radio. They're inexpensive.
numbfingers
Re: stereo system
#8 Post by numbfingers » Wed Mar 02, 2016 11:40 am
Thank you gentlemen
