Adhesive Removal.....
Posted: Fri Apr 01, 2016 6:26 pm
by SamiGuy
OK... Had to remove the "old" numbers on my toon, and the numbers and state sticker left a lot of adhesive behind. Used a bunch of "Goof-Off" with minimal results. This is on the painted "black" side panels. Acetone and Lacquer Thinner of course are out. WD-40, Mineral Spirits/Paint Thinner? What do you suggest?
Thanks in advance!!
Sami
Re: Adhesive Removal.....
Posted: Fri Apr 01, 2016 6:57 pm
by LittleRiver
gas....... simple, quick, effective.
Posted: Fri Apr 01, 2016 11:32 pm
by Reiner
WD 40, works wonders.
Posted: Sat Apr 02, 2016 3:25 am
by Bryden24shp
#2.... not that kind of #2.... #2 on the WD40...
Posted: Sun Apr 03, 2016 6:12 am
by rancherlee
WD-40 or a Heat gun set to low have worked for me. I used a combo of both when I removed all the factory graphics on my resto!
Posted: Sun Apr 03, 2016 6:47 am
by teecro
I've always had good luck with Mineral Spirits, Napata etc... WD40 works good and I also really like Brake Cleaner too.... If not an extreamly old weathered sticker a Heat Gun works like a champ...
Posted: Mon Apr 04, 2016 9:29 am
by robertm
3M adhesive remover is night and day better than goo-gone.
http://www.amazon.com/3M-03618-Adhesive ... ve+remover
Posted: Tue Apr 05, 2016 6:40 pm
by SamiGuy
UPDATE!! Had some WD-40 handy, so I tried that. Worked like a champ! (Had the gas can out if that didn't work.....plus a fire extinguisher!!) Really appreciate all the input and help. Hope to get this bad boy in the water soon!
Thanks!
Sami
Posted: Wed Apr 06, 2016 3:36 pm
by PlaynDoc
SamiGuy wrote:UPDATE!! Had some WD-40 handy, so I tried that. Worked like a champ! (Had the gas can out if that didn't work.....plus a fire extinguisher!!) Really appreciate all the input and help. Hope to get this bad boy in the water soon!
Thanks!
Sami
yeah, it's always best to try WD-40 before using gasoline and matches... sure glad you had the extinguisher handy!
Posted: Wed Apr 06, 2016 6:03 pm
by RonKMiller
Solvents?
You guys are working (and sniffing) WAY too hard. :eviltaunt
Next time turn a nightmare job into 30 seconds and be DONE:
http://www.ebay.com/itm/ABN-Pinstripe-D ... 1723839028
Posted: Wed Apr 06, 2016 6:33 pm
by SamiGuy
Damn.....now you tell me !!! :lol3
