Pontoon stuff power bimini
mzodarg
#1 Post by mzodarg » Fri Jul 01, 2016 6:36 am
Just bought one of these for my toon. Does anyone have any lessons learned on the install that they would like to share?
TIA,
MIke
[/color]
Re: Pontoon stuff power bimini
#2 Post by curtiscapk » Fri Jul 01, 2016 7:42 am
mzodarg
#3 Post by mzodarg » Fri Jul 01, 2016 8:04 am
curtiscapk-thanks seen it, was looking for others who have installed one.
Mike
[/color]
vlxerdon
#4 Post by vlxerdon » Fri Jul 01, 2016 8:40 am
mzodarg wrote:curtiscapk-thanks seen it, was looking for others who have installed one.
Mike
The instructions are pretty straight forward. I did my install by myself ( wife was unable to help and no one else around ) Do not do this by yourself ( hell on wheels ) Get a friend,enemy or neighbor to help. A two person job if there ever was one.
That said, I really enjoy being able to push a button or switch to raise and lower the top. Wish I could say I found a magical trick to the install but...... With two people it will be a very easy job. Enjoy.
1994 Starcraft Stardeck 200
1998 Johnson 90HP
98 5.9 V8 Magnum Dodge Ram
Gonefishing
#5 Post by Gonefishing » Fri Jul 01, 2016 8:57 am
Did mine alone and had no problems. Just took a little longer. It is really nice to just push a button and up it goes.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
mzodarg
#6 Post by mzodarg » Fri Jul 01, 2016 12:38 pm
vlxerdon, Gonefishing.
Thanks for your input! Ordered it this morning and it's already shipped. Hope it doesn't arrive to earlier as I'm in the process of rigging a new waverunner to fish off of. I would like to finish before it gets here.
Have the instruction improved as far as the wiring goes. I read somewhere that the wiring diagram was not the best?
[/color]
lightpants
#7 Post by lightpants » Tue Jul 05, 2016 11:43 am
Remember, if you are going to install a navigation light on the top, you need to fish the wire up through the frame when you install the top.
wickerbill
#8 Post by wickerbill » Tue Jul 05, 2016 12:43 pm
I can offer one "gotcha" that I experienced after installing the power top on my boat. It was my of own doing and not a fault of the the top.
Mine kept popping the auto-reset breaker when being lowered. After removing the remote box and just wiring to the switch direct with the same results, tying to a dedicated wire from the battery, I finally removed the canvas and the cross tube of the powered bows and ran them independently. They both ran fine.
As it turns out when installing the cross tube in the powered bows, I was over zealous on making sure the powered bow tubes came down completely square on the second bow. The result of this was the powered bows were being pushed out to the point of putting the bows into a bind in the drive head pivot channels. I then put the cross tube in place and ran the assembeled bow with no screws in it and let it find it's own spread throughout the cycle. I then just put 1 screw back into the cross tube and am letting the other end "float" as needed. Haven't had a problem since. Works like a dream...love it!
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
2014 Berkshire STS 231RFC
115 Mercury 4 stroke
vlxerdon
#9 Post by vlxerdon » Wed Jul 06, 2016 6:15 am
mzodarg wrote:vlxerdon, Gonefishing.
Sorry I did not get back sooner. You most likely have your top by now, It's been a while but I don't remember having any problem with any of the instructions including the wiring.
I noticed one poster had no problems doing the install by himself. I'm afraid my age is showing here, at 70 I don't move as good as I used to . :)
1998 Johnson 90HP
crookedlaker
#10 Post by crookedlaker » Thu Jul 07, 2016 8:41 am
check out my review in the manufacturers reviews
I have listed some tips and photos of my install
I have installed one and helped a friend on his also
I would not own a boat without one
the hardest part is running the wiring neatly
take your time and do it right
good luck
Mike
2017 Harris Sunliner 200
Tri-toon P+ Package
2017 Mercury 150 4 stroke
Gonefishing
#11 Post by Gonefishing » Thu Jul 07, 2016 9:09 am
I didn't have a wiring problems with mine. Everything went smoothly for me.
2013 115 Yamaha
JEB
#12 Post by JEB » Sun Jul 10, 2016 1:40 pm
@crookedlaker. Where can I find your review at? Didn't see it on pontoon stuff and didn't see ant reviews at per-Arm.com.
JEB
NEW-2019 Barletta L25UC
2019 Mercury 300 4 Stroke
EZ Loader trailer.
1985 Starcraft SD240
New to me-1998 Johnson 150 carbureted
Traded in-1979 Johnson 140
Upgraded transom
Added cross members
Glen Rose, Texas
crookedlaker
#13 Post by crookedlaker » Mon Jul 11, 2016 5:27 am
it is on the pontoonforum.com
here is the link
viewtopic.php?f=3&t=21664
I love my top
will have on my next boat
Mike
Tri-toon P+ Package
mzodarg
#14 Post by mzodarg » Tue Jul 12, 2016 5:02 am
Thanks to everyone who provided input!
I haven't attempted an install yet, been having to much fun on my Waverunner. Most likely won't get to it until the end of July. I'll be sure to post my results.
Mike
[/color]
