guy48065
#1
Post
by guy48065 » Thu Sep 15, 2016 7:33 am
The original rocker switch used from 96 to present is no longer available and now you must replace the remote handle with a new one with pushbuttons embedded.
My question is: how do you like it? Does it work better & last longer than the troublesome rocker switch?
Ive temporarily replaced my defective switch with a momentary toggle.
Mark
Rush Lake, Atlanta, MI
Gearbanger
#2
Post
by Gearbanger » Tue Sep 20, 2016 8:23 am
Given the location, I assume that is the trim switch. Looks like a pretty good job to me, if it works I would probably stick with the switch you have installed already and if you believe it durable enough to handle the electrical load.
