My 2000 Johnson manual shows fogging the motor through a convenient schrader port on the primer. Problem is I couldn't find any cans with the correct hose. I looked at all the local auto parts stores & also at Bass Pro but all I found were skinny little straws on cans.
Does anyone still package fogging oil this way and do I have to go to a marina to buy it?
Fogging oil with schrader end
Mark
Rush Lake, Atlanta, MI
Re: Fogging oil with schrader end
I don't know if there is one in your area, but if there is a repair shop specializing in Johnson/Evinrude, give them a call. They may be able to help.
I know I've seen them but I can't remember where. It may have been West Marine.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
Try these guys.
http://www.marineengineparts.com/evinru ... g-oil.html
They mention an injector valve at the bottom of the page. I think this is what you need.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
Well that link and a little help from Google and I found there is an adaptor available for use on other cans of fogging oil.
http://www.marineengineparts.com/evinru ... embly.html
[img]http://www.marineengineparts.com/media/ ... 763644.jpg[/img]
Mark
Oh I keep forgetting that BB code doesn't work here. Is that a permanent problem or will links and formatting work again some day?
Mark
Well there you go Guy. Good luck.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
