scratches and mars
- seminolewind
scratches and mars
Can you compound and wax the "gel coat" to remove surface scratches and small discolored spots or marks? (Mostly on the rim)
Re: scratches and mars
Yes this can be done and it pretty easy to do first you will need a good cleaner product, I use the Meguiar's mirror glaze ultra cut and a buffer, this will remove small scratches and glaze on the gel coat, then follow it up with a good carnuba wax, this wok great for a my Nitro bass boat that is 25 years old I do this once in the spring every year,Tim
1992 TRACKER 24D
JOHNSON 115 GT PRO
JOHNSON 115 GT PRO
- seminolewind
Sounds good!
