Guys, I have a quick question. The bunks on my boat lift seem to have the correct separation; however, on occasion, I don't get the pontoon perfectly centered, so the bunks on one side or the other don't perfectly cradle the pontoon. For instance, there will be a small gap between the pontoon and one board, but that same pontoon will be resting flush with the other board on the bunk. It's just slightly off centered on one side....I have no idea if I explained that well enough.
The toon is fully supported so I figured no big deal. What do you all think?
Boat lift Question
Boat lift Question
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
Re: Boat lift Question
A lot of people around here just have boards that are flat and the boat rests on the keels so u don't think it should be a problem.
