23' xcursion with 115 Yamaha height question
Littlehoe
#1 Post by Littlehoe » Mon May 29, 2017 3:11 pm
Hey all. I'm running a 15 pitch 4 blade spitfire prop and I seem to be just under the rpm I should be at with a load. I put on a 13 pitch but then I am banging the limiter. The boat has the 3/4 length center tube. Where do the guys with similar engines and boats run their engines? Mine is currently all the way down.
[IMG]http://i31.photobucket.com/albums/c371/ ... segh57.jpg[/IMG]
[IMG]http://i31.photobucket.com/albums/c371/ ... 0y9o1d.jpg[/IMG]
DWRAT
Re: 23' xcursion with 115 Yamaha height question
#2 Post by DWRAT » Mon May 29, 2017 4:29 pm
I would go up 1 hole, maybe 2 holes.
You want your motor fin even with the bottom the boat.
The fin I am referring to is the plate above the prop, i'm sure there's a different word for it.
Littlehoe
#3 Post by Littlehoe » Sun Jun 04, 2017 7:54 pm
ok so I went up 2 holes... no change lol... runs the same rpm.
