Old motor question...
Posted: Thu Jul 06, 2017 10:22 pm
by Retired OG
Is there a fairly reliable way to gauge the temperature of an old motor? I'm getting close to the point where I'm gonna need to stick it in the lake to tune the carbs and check for leaks. The motor is a 1972 Evinrude 50 hp. I'm gonna mount a good running 15 hp. off one pontoon "just in case".
Re: Old motor question...
Posted: Fri Jul 07, 2017 3:47 am
by JLester273
I'd be interested in this too. I always like to know stuff like this. I think I saw a youtube video of someone adding a temp gauge. I didn't watch it I just saw the title ...might have to look for it again.
Posted: Fri Jul 07, 2017 1:57 pm
by MH Hawker
i would suggest this or put your hand into the pea stream or on the cylinder head,,have you changed the pump impeller
https://www.harborfreight.com/infrared- ... 93984.html
Posted: Fri Jul 07, 2017 9:37 pm
by Retired OG
[quote="MH Hawker"]i would suggest this or put your hand into the pea stream or on the cylinder head,,have you changed the pump impeller
https://www.harborfreight.com/infrared- ... 93984.html[/quote]as
That infrared is exactly what I was looking for....Thanks
