21mph at 6000 or 22mph at 5100rpm?
Otisville
#1 Post by Otisville » Thu Aug 31, 2017 5:37 pm
Is it better to go 22mph at 5100 or 21mph at 6k rpm? The difference between a 14. 11 and a 14. 13 pitch. I have a 2004 50 horse Yamaha on a 2019re sweetwater.
[b]2005 Sweetwater 2019 RE [/b]
[i]Yamaha 50 4 stroke[/i]
captain28570
Re: 21mph at 6000 or 22mph at 5100rpm?
#2 Post by captain28570 » Thu Aug 31, 2017 5:51 pm
I would say you need a 12 pitch prop. Get the rpms around 5500. Whats the max rpm on the motor? 2 or 4 stroke?
Otisville
#3 Post by Otisville » Thu Aug 31, 2017 5:58 pm
Manufacturer says optimum mom is 5K to 6K and it's a four stroke.
#4 Post by ROLAND » Fri Sep 01, 2017 1:56 am
I have a yamaha 75 four stroke.. and I believe the specs show the rev alarm will sound at approx. 6200 rpm's. My boat wide open is turning just a hair under 6K rpm's.... A few years back I changed props and she topped out at around 5K rpm's and the guys on this forum told me I was over propped... So I went back to my original prop where she runs about 23 mph just under 6K. Hope this helps.
Otisville
#5 Post by Otisville » Fri Sep 01, 2017 6:31 am
What did you do with the prop? Can they be returned? No blemishes on mine. Used once.
captain28570
#6 Post by captain28570 » Fri Sep 01, 2017 6:54 pm
Yea close to 6000 as you can get it with a light load. Toons are harder to get max rpms out of them. You lug the engine if you only turning 5100 rpms.
DWRAT
#7 Post by DWRAT » Fri Sep 01, 2017 9:31 pm
I can tell you that at 5,100 rpms you are saving gas big time over 6,000 rpms.
I would only run the smaller prop for when you have 10 people on your boat.
BTW, I have the exact same situation on my Merc 150 and base my info off my Mercury smart craft gauge.
#8 Post by ROLAND » Sat Sep 02, 2017 1:09 am
[quote="Otisville"]What did you do with the prop? Can they be returned? No blemishes on mine. Used once.[/quote]
I returned it to marine shop where I bought it. Called him up and told him how the new prop was only cranking out about 5k rpm's and told him I wanted to go back to the original pitch prop. He ordered me a new one and it was at his shop like 3 days later..
jrolin1
#9 Post by jrolin1 » Sat Sep 02, 2017 4:55 am
Make sure your motor height is correct. If it is not you get strange results with different props.
Otisville
#10 Post by Otisville » Sat Sep 02, 2017 2:13 pm
What is the simple science of engine height? How I check? The engine has been at the same height for years. Thx
toondog
#11 Post by toondog » Sun Sep 03, 2017 9:09 am
It's a good idea to have a spare prop along with hardware and floating prop wrench. 5100 rpm is a little low though.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
jrolin1
#12 Post by jrolin1 » Sun Sep 03, 2017 11:20 am
[quote="Otisville"]What is the simple science of engine height? How I check? The engine has been at the same height for years. Thx[/quote]
[img]http://i67.photobucket.com/albums/h307/ ... olow-1.jpg[/img]
http://nodakangler.com/forums/showthrea ... ine-height
