Weighed my boat on the trailer today. Heavier than I thought
captain28570
#1 Post by captain28570 » Sun Sep 03, 2017 6:55 pm
22 foot Manitou Tritoon with the SHP package 150 HO Evinrude G2.
Had 20 gallons of fuel, 2 Batteries and maybe 200 pounds of other stuff.
5000 pounds with trailer included.
They list dry weight of boat at 2550. Motor is around 530.
Trailer must weigh a lot :shock:
willy13
Re: Weighed my boat on the trailer today. Heavier than I thought
#2 Post by willy13 » Sun Sep 03, 2017 7:49 pm
My twin axle 22-24 ft Yacht Club trailer weighs 975 lbs.
#3 Post by Bryden24shp » Mon Sep 04, 2017 3:23 am
My trailer for the last Manitou weighed 2850. Was a 30 foot long Heritage Custom heavy duty, tri bunks with tandems and full fenders. Total boat, motor and trailer weight when I set the tongue weight on the trucks hitch, at the Cat Scale, was right at 7200 with no fuel or extras.
#4 Post by Bamaman » Mon Sep 04, 2017 6:18 pm
[quote="Bryden24shp"]My trailer for the last Manitou weighed 2850. Was a 30 foot long Heritage Custom heavy duty, tri bunks with tandems and full fenders. Total boat, motor and trailer weight when I set the tongue weight on the trucks hitch, at the Cat Scale, was right at 7200 with no fuel or extras.[/quote]
Bryan:
It is nice to have a good trailer, but an extremely heavy pontoon trailer is just not needed. When a pontoon/tritoon is sitting on a trailer on carpeted V bunks running the length of the hull, the hull is giving much of the structure of the combined load. Towing huge loads that can be reduced is a waste of fuel of the tow!vehicle. My 1,000 lb. trailer is sufficient for my entry level Bennie with 150 hp.
#5 Post by Bryden24shp » Wed Sep 06, 2017 4:59 am
[quote="Bamaman"][quote="Bryden24shp"]My trailer for the last Manitou weighed 2850. Was a 30 foot long Heritage Custom heavy duty, tri bunks with tandems and full fenders. Total boat, motor and trailer weight when I set the tongue weight on the trucks hitch, at the Cat Scale, was right at 7200 with no fuel or extras.[/quote]
Bryan:
It is nice to have a good trailer, but an extremely heavy pontoon trailer is just not needed. When a pontoon/tritoon is sitting on a trailer on carpeted V bunks running the length of the hull, the hull is giving much of the structure of the combined load. Towing huge loads that can be reduced is a waste of fuel of the tow!vehicle. My 1,000 lb. trailer is sufficient for my entry level Bennie with 150 hp.[/quote]
Maybe around town and an occasional highway tow. But when you tow 5 to 8000 miles a season, as I do, I want a trailer that's gonna hold up. I don't want to be or create a casualty on the interstate, because I bought a cheap trailer.
Wreck Tangle
#6 Post by Wreck Tangle » Wed Sep 06, 2017 6:32 am
[quote="Bryden24shp"]I want a trailer that's gonna hold up. I don't want to be or create a casualty on the interstate, because I bought a cheap trailer.[/quote]
I also assume you have better than bare minimum brakes installed on your axles?
#7 Post by Bryden24shp » Wed Sep 06, 2017 9:02 am
[quote="Wreck Tangle"][quote="Bryden24shp"]I want a trailer that's gonna hold up. I don't want to be or create a casualty on the interstate, because I bought a cheap trailer.[/quote]
I also assume you have better than bare minimum brakes installed on your axles?[/quote]
Oh ya.. For those Missouri hills, you need good brakes. 4 wheel disc with dual piston calipers, with electric reverse lock-out.
WI-RiverRat
#8 Post by WI-RiverRat » Wed Sep 06, 2017 10:59 am
[quote="captain28570"]22 foot Manitou Tritoon with the SHP package 150 HO Evinrude G2.
Trailer must weigh a lot :shock:[/quote]
Captain - When you add 160lbs for fuel + 40lbs for batteries + 200lbs misc _ 2550lbs + 530Lbs = 3480lbs wet boat & engine.
Leaves about 1500lbs for your trailer. If you can leave the boat tied up, easy enough to know for sure. It does add up quick!
Wisconsin Summers are TOO Short :)
2001 - 22' Bennington w/ 115Hp Merc 4 Stroke 25 GPS
2008 - 3 Seat 155Hp Sea Doo
Canoe
Kayak
1992 - 18' Rinker Captiva w/ 175Hp I/O (Gone)
1975 - 15' StarCraft Tri-Hull w/ 70Hp Outboard (Gone)
