I just got a brand new Montego Bay tritoon with an etec g2 200 HO engine.
It normally sits in a marina on a lift except for 10 days - where I plan on towing it to northern Wisconsin.
My question is - when towing, do I put the cover on or off?
My preference would be to leave the cover off.
Towing a pontoon boat - cover on or off?
Re: Towing a pontoon boat - cover on or off?
Always off.
2014 Premier Gemini 201
Tow Vehicle: 2019 F-150
Home Port: Newfound Lake, NH
[quote="Coldbrew"]Always off.
[/quote]
Thanks much!
I should not worry about the chairs getting all out of whack because of them going back and forth?
Thanks much!
- NonHyphenAmerican
Hyperx,
My chairs all secure in the folded position and I Swivel and then lock them in the rear facing position.
I also use a small shrink wrap about 4" wide to shrink wrap things like the depth finder cover in place so I don't lose anything in the wind.
- killerkernrich
OFF
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
yep, off.
Cover pff, Bimini top down in trailering position, and front & rear gates blocked open. I drop the seat backs all the way flat and take the tables out, too. Let the air flow through. They pull easier and bumps the fuel economy a little. Some manufacturers recommend removing the drivers wind screen from the pedestal, too.
