Fixed My Cavitation problem
Posted: Fri Sep 15, 2017 8:57 pm
2013 xcursion with a 150 merc.tried everything,lower engine,change props.put on a whale tale,even put on a jack plate to lower it more.
come to find out I was missing a 2dollar and 10 cent plastic washer/grommet that goes between the lower hub area and the prop.makes tons of sense,keeps the exhaust gas from escaping around the prop huband going thru the middle of prop as designed.
hope this helps anyone.
since I put this on not 1 bit of cavitation
