I have a question regarding the carpeting that is around the seat bases on my pontoon. It is a 2006 Premier. My seats are vinyl, however the bottom base of the seats are covered in carpet. It is in the area where the under seat lighting is.
I am assuming that there is seat vinyl behind the carpet? They must just glue the carpet to the vinyl? I am thinking about taking the carpet out of my boat and putting in vinyl flooring. If I do so, I would want to the remove the carpeting around the seat bases and just have the vinyl seat material there.
Has anybody pulled the carpeting off around their seat bases? Any advise on the process to switch from carpet to vinyl flooring? Thanks for your input!
Removing carpeting at seat base? Switching to vinyl flooring
Re: Removing carpeting at seat base? Switching to vinyl flooring
We don't have a Premier but our carpet is glued to the marine plywood decking. To replace the carpet, everything has to be removed. Helm, seats, changing station, everything.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
